2009-10-07, 11:15
Change between two diffrent xorg.conf on XBMC [LIVE] Camelion 9.11 with a remote. Usefull for switching between a plasma, LCD or a beamer...
(This guide assume the user is "xbmc")
Connect to your XBMC computer with putty or similiar.
You can also open up a terminal session alt + F2.
All changes below is made by a terminal program or session.
1. Start irexec, needed for capturing remote commands and execute script:
Open rc.local
Add the following line before exit 0:
2. Create config file for irexec (.lircrc):
Add the following:
This will execute the script "toggle.sh" by pressing the "Clear" button on an MCE remote, change if needed.
3. Check if irexec starts (optional):
Reboot computer and put in this in the terminal:
If everyting works it should answer with:
xbmc 1554 1 0 14:00 ? 00:00:00 /usr/bin/irexec -d /home/xbmc/.lircrc
xbmc 2114 1646 0 14:16 pts/0 00:00:00 grep --color=auto irexec
4. Create two xorg.conf (one for each screen/setup):
First we need to know the PCI bus ID of the graphic cards.
(this is for nvidia cards, change to ati if needed)
Output:
01:00.0 VGA compatible controller: nVidia Corporation G96 [GeForce 9500 GT] (rev a1)
02:00.0 VGA compatible controller: nVidia Corporation G96 [GeForce 9500 GT] (rev a1)
The first numbers tell us what we need to know.
- PCI:1:0:0 and PCI:2:0:0 this is the bus id's for each cards.
Create xorg0.conf
Add the text from your orginal xorg.conf or try mine.
Don't forget to change the BusID lines with our numbers.
Create the second file, xorg1.conf
5. Edit the files you just created, to make them use diffrent screens:
One should have "Screen0" the other "Screen1".
6. Make a script that change between the xorg0.conf and xorg1.conf:
Add the following:
7. Remove password from root:
Add in the end of that file:
Thats it
If you make small changes to the above it can also be usefull for:
-one graphic card with two resolution one for each vga/DVI port.
//alvess
Open rc.local
sudo nano /etc/rc.local
su -c '/usr/bin/irexec -d /home/xbmc/.lircrc' -l xbmc
sudo nano /home/xbmc/.lircrc
Add the following:
begin
remote = mceusb
prog = irexec
button = Clear
config = sudo sh /etc/X11/toggle.sh
repeat = 0
delay = 0
end
ps -ef | grep irexec
lspci | grep -i nvidia
Output:
Create xorg0.conf
sudo nano /etc/X11/xorg0.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder63) Mon Mar 23 15:33:27 PST 2009
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:1:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:2:0:0"
Screen 0
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "NoLogo" "True"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
sudo cp /etx/X11/xorg0.conf /etc/X11/xorg1.conf
sudo nano /etc/X11/xorg1.conf
sudo nano /etc/X11/toggle.sh
Add the following:
#!/bin/sh
# Shell script used to toggle between two xorg.conf files on XBMC [Live/Linux]
# namely $CONF_ONE and $CONF_TWO.
# To setup the script you need to change the value of two maybe three variables.
# Begin by changing $CONF_ONE and $CONF_TWO. They should contain the path to
# the two xorg.conf files you which to toggle between.
# The script will store information inside the $TOGGLE_CONF file (toggle.conf).
cd /etc/X11
# configuration (userdefined)
CONF_ONE="xorg0.conf" # userdefined xorg.conf one
CONF_TWO="xorg1.conf" # userdefined xorg.conf two
# constants
CONF="xorg.conf" # path to the xorg.conf file used by X.org
TOGGLE_CONF="toggle.conf" # path to this script's own configuration file
CONF_DEF=$CONF_ONE # default xorg.conf that is used if no $TOGGLE_CONF file exists
# other vairables
FILE="" # store new the X.org config file name
LINE="" # used when readin this script's config file ($TOGGLE_CONF)
# set the given config file
setConfigFile() {
FILE="$@" # get all args
# set the new X.org config file
echo "Setting $FILE as X.org's config"
rm -f $CONF
ln -s $FILE $CONF
# save the name of the new config, so that we know which file to change
# to the next time we toggle
echo "Saving '$FILE' to $TOGGLE_CONF for later use"
echo $FILE > $TOGGLE_CONF
# in order for the changes to take effect, we need to restart X.org
echo "Restarting XBMC"
killall xbmc
startx &
sleep 2
xbmc &
exit
# read the script's config in order to know which X.org confing to toggle to
echo "Reading $TOGGLE_CONF"
if [ ! -f $TOGGLE_CONF ]; then
echo "No $TOGGLE_CONF found, setting default X.org config"
setConfigFile $CONF_DEF
else
# read the script's config file
while read LINE; do
echo "Currently used X.org config: '$LINE'"
# switch to the correct X.org config
if [ $LINE != $CONF_ONE ]; then
setConfigFile $CONF_ONE
else
setConfigFile $CONF_TWO
fi
done < $TOGGLE_CONF
fi
exit
sudo visudo
xbmc ALL=NOPASSWD: ALL
Thats it
//alvess
