Batch download Lyrics for XBMC Lyrics script
The lyrics downloaded will be saved to "txt" file in the selected folder
---- Instalation Instructions ----
1.
Download BatchLyricsDownload Script.zip
2.
Copy BatchLyricsDownload folder to user's script folder
--- on ATV /users/frontrow/Application support/XBMC/scripts/
--- on Mac OS /users/{your user name}/Application support/XBMC/scripts/
--- on Win32 \Documents and Settings\{your user name}\Application Data\XBMC\scripts\ <--- Application Data folder might be hidden.
--- on Linux /home/{your user name}/.xbmc/scripts
3.
Set the desired download location in Script settings, by default it is set to XBMC Lyrics default folder
To enter the settings go to Scripts:
Apple Tv: Highlight BatchLyricsDownload and hold "menu", then select script settings
Keyboard: Highlight BatchLyricsDownload and press "c", then select script settings
XBOX: Highlight BatchLyricsDownload and select 'select' button on IR, then select script settings
----- Usage Instructions ------
Run the script from scripts menu and select folder that contains mp3 files
----- Notes --------
- I have only tested this on Mac
- selecting too many songs will take a while to download
- your songs need to have proper ID3 tag (artist and song title)
- lyrics downloaded have only been tested with XBMC Lyrics script
Enjoy and let me know how it works for you
Zeljko
Ok Installed script and left directory to XBMC lyrics.
I copied about 50 songs to a unique directory to test script on.
I ran script and 1 of 49 Songs displays. (In the lyrics directory I see the Artists directory created and the first song.txt which is 0 bytes
Nothing happens after that.
I have to force close XBMC
Running win XP
detroitdr Wrote:Ok Installed script and left directory to XBMC lyrics.
Running win XP
please post the log
let me see where it fails...
, sorry dont have Win to test.
Zeljko
detroitdr Wrote:http://pastebin.com/m3ef12abe
I hope this is what you are looking for
yeah, Thanks!
Quote:#
18:26:01 T:4484 M:1184067584 NOTICE: http://lyricwiki.org/index.php?title=2%2...ction=edit
18:26:01 T:4484 M:1184321536 ERROR: CThread:taticThread : Access violation at 0x7c91b21a: Writing location 0x00000010
18:26:01 T:4484 M:1184321536 INFO: Python script stopped
18:26:01 T:4484 M:1184370688 DEBUG: Thread 4484 terminating
Try again please... Same download link
Amet Wrote:[SIZE="4"]
2. Copy BatchLyricsDownload folder to user's script folder
--- on Win32 \Documents and Settings\{your user name}\Application Data\XBMC\scripts\ <--- Application Data folder might be hidden.[/INDENT]
i've had not much time to test this, but there are two things i've noticed.
this was tested on linux, so maybe these are platform specific issues.
- script crashes when there's a special character in the song title, like Æ
Debug Log
- i doesn't work when your music is stored on a smb drive
Debug Log
other than that, once again, a very cool script. ;-)
cheers mate.
ronie Wrote:--- on Linux /home/{your user name}/.xbmc/scripts
thanks!
ronie Wrote:i've had not much time to test this, but there are two things i've noticed.
Debug Log
do you mind trying with debug log off in script settings?
ronie Wrote:- i doesn't work when your music is stored on a smb drive
Debug Log
I will see what I can do about it... it shouldn't be too difficult
ronie Wrote:other than that, once again, a very cool script. ;-)
cheers mate.
Thanks mate
Cheers
detroitdr Wrote:Ok unfortuantly no difference. Here is the debug log
http://pastebin.com/m333103ec
Thank-you
I have tested on windows and it works
, not sure why it fails on your side.
you have downloaded 0.7? try disabling the debug log as well in script settings
Its almost 4AM here, I need some sleep
, I will do some more tests and let you know tomorrow.
Cheers
Zeljko
Amet Wrote:do you mind trying with debug log off in script settings?
sure, no problem.
without debuglogging the script doesn't crash.....but xbmc does.
much better! ;-P
crashlog
Amet:
Ok the script says .5 so I redownloaded it and sure enough firefox cache just gave me the same file.
I downloaded the latest version and installed. a new MACOS directory was also there.. so it's got to be the latest.
NOTE: script still says .5 though.. so you might want to change that.
Good news: It seemed to work on the 49 files. Now I'll try the directory with 6500 songs in it.
Will let you know.
THANK-YOU again in advance.
Amet:
One thing I noticed is that if you try to change directories... your syntax is messed up and the script crashes. Hitting the default button didn't help either.. so I had to go into script data, and delete the XLM file it creates to reset to your initial directory setting..... which does work.. however has an extra LYRICS directory.
Not a big deal.. easy work around.. however if you want to perfect the script.. your choosing a directory doesn't work. (You actually can't create a new directory to type in the full path or anyhting...)
Great work. I'll try next on the 5950 songs remaining..
This sounds like another great application Amet, however the download link doesn't seem to work - any chance anyone could upload it again. Cheers.
That's odd, doesn't seem to work for me, I'm getting:
Google Error
Not Found
The requested URL /files/BatchLyricsDownload%20Script.zip was not found on this server.
Just gone to your google code homepage and downloaded it from the link on there - that seems to do the trick. I'll give it a test and let you know how it works on my library of 11,000 songs! Cheers
