Full Version: TheTVDB.com scraper
Pages: 1 2
Hello so i have this issues with my tv serives. TheTVDB.com scraper gets the banner, season thumb and fan art for some shows and not for other even though they are on TheTVDB.com website. It says downloading thumb and then appears blank. I'm using the most current build of xbmc (not 9.11 alpha)
hartwick Wrote:I'm using the most current build of xbmc (not 9.11 alpha)
Please be more specific and include a debug log.
for shows like the middle and lie to me(wont get season 2 thumb) i go to the show and set season thumb it comes says downloading thumb and the the picture is blank and it says remote thumb. does the same for the middle for everything. How do i get you a debug log
see his / my signature
ok so here is the debug log
20:36:13 T:2156 M:1087213568 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 1000
20:36:13 T:2156 M:1087213568 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
20:36:13 T:2156 M:1087483904 INFO: Loading skin file: DialogVideoInfo.xml
20:36:13 T:2156 M:1087459328 DEBUG: Load DialogVideoInfo.xml: 16.54ms
20:36:13 T:2156 M:1087520768 DEBUG: Alloc resources: 17.10ms (16.71 ms skin load, 0.25 ms preload)
20:36:13 T:2156 M:1087516672 DEBUG: FileCurl::Open(0012AD10) http://images.thetvdb.com/banners/graphi...021-g4.jpg
20:36:13 T:2156 M:1087479808 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://images.thetvdb.com
20:36:14 T:2156 M:1086582784 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:14 T:2156 M:1086586880 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:14 T:2156 M:1086586880 DEBUG: FileCurl::Close(0012AD10) http://images.thetvdb.com/banners/graphi...021-g4.jpg
20:36:15 T:2156 M:1084264448 DEBUG: SDLKeyboard: scancode: 77, sym: 275, unicode: 0, modifier: 1000
20:36:15 T:2156 M:1084264448 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
20:36:16 T:2156 M:1084489728 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 1000
20:36:16 T:2156 M:1084489728 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
20:36:16 T:2156 M:1084538880 INFO: Loading skin file: FileBrowser.xml
20:36:16 T:2156 M:1084792832 DEBUG: Load FileBrowser.xml: 2.58ms
20:36:16 T:3988 M:1084841984 DEBUG: thread start, auto delete: 0
20:36:16 T:2676 M:1084829696 DEBUG: thread start, auto delete: 0
20:36:16 T:2156 M:1084825600 DEBUG: Alloc resources: 0.07ms (0.00 ms skin load, 0.05 ms preload)
20:36:16 T:3988 M:1084821504 DEBUG: FileCurl::Open(05DEF5B4) http://images.thetvdb.com/banners/graphi...021-g4.jpg
20:36:16 T:2676 M:1084715008 DEBUG: FileCurl::Open(05EEF5B4) http://images.thetvdb.com/banners/graphical/95021-g.jpg
20:36:16 T:2676 M:1084669952 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://images.thetvdb.com
20:36:17 T:2676 M:1084928000 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:17 T:2676 M:1084940288 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:17 T:2676 M:1084940288 DEBUG: FileCurl::Close(05EEF5B4) http://images.thetvdb.com/banners/graphical/95021-g.jpg
20:36:17 T:2676 M:1084940288 DEBUG: FileCurl::Open(05EEF5B4) http://images.thetvdb.com/banners/graphi...021-g3.jpg
20:36:17 T:3988 M:1084940288 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:17 T:3988 M:1084940288 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:17 T:3988 M:1084952576 DEBUG: FileCurl::Close(05DEF5B4) http://images.thetvdb.com/banners/graphi...021-g4.jpg
20:36:17 T:3988 M:1084952576 DEBUG: FileCurl::Open(05DEF5B4) http://images.thetvdb.com/banners/graphi...021-g2.jpg
20:36:18 T:3988 M:1085313024 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:18 T:3988 M:1085325312 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:18 T:3988 M:1085325312 DEBUG: FileCurl::Close(05DEF5B4) http://images.thetvdb.com/banners/graphi...021-g2.jpg
20:36:18 T:3988 M:1085321216 DEBUG: FileCurl::Open(05DEF5B4) http://images.thetvdb.com/banners/posters/95021-1.jpg
20:36:18 T:2676 M:1085321216 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:18 T:2676 M:1085333504 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:18 T:2676 M:1085333504 DEBUG: FileCurl::Close(05EEF5B4) http://images.thetvdb.com/banners/graphi...021-g3.jpg
20:36:18 T:2676 M:1085333504 DEBUG: Thread 2676 terminating
20:36:20 T:3988 M:1085751296 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:20 T:3988 M:1085763584 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:20 T:3988 M:1085763584 DEBUG: FileCurl::Close(05DEF5B4) http://images.thetvdb.com/banners/posters/95021-1.jpg
20:36:20 T:3988 M:1085763584 DEBUG: Thread 3988 terminating
20:36:25 T:2156 M:1086242816 DEBUG: SDLKeyboard: scancode: 80, sym: 274, unicode: 0, modifier: 1000
20:36:25 T:2156 M:1086242816 DEBUG: CApplication::OnKey: 61480 pressed, action is 4
20:36:26 T:2156 M:1086365696 DEBUG: SDLKeyboard: scancode: 77, sym: 275, unicode: 0, modifier: 1000
20:36:26 T:2156 M:1086365696 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
20:36:27 T:2156 M:1086341120 DEBUG: SDLKeyboard: scancode: 72, sym: 273, unicode: 0, modifier: 1000
20:36:27 T:2156 M:1086341120 DEBUG: CApplication::OnKey: 61478 pressed, action is 3
20:36:27 T:2156 M:1086357504 DEBUG: SDLKeyboard: scancode: 77, sym: 275, unicode: 0, modifier: 1000
20:36:27 T:2156 M:1086357504 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
20:36:28 T:2156 M:1086357504 DEBUG: SDLKeyboard: scancode: 77, sym: 275, unicode: 0, modifier: 1000
20:36:28 T:2156 M:1086357504 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
20:36:28 T:2156 M:1086332928 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 1000
20:36:28 T:2156 M:1086332928 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
20:36:30 T:2156 M:1086402560 DEBUG: SDLKeyboard: scancode: 77, sym: 275, unicode: 0, modifier: 1000
20:36:30 T:2156 M:1086402560 DEBUG: CApplication::OnKey: 61479 pressed, action is 2
20:36:30 T:2156 M:1086402560 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 1000
20:36:30 T:2156 M:1086402560 DEBUG: CApplication::OnKey: 61453 pressed, action is 7
20:36:30 T:2156 M:1086406656 INFO: Loading skin file: FileBrowser.xml
20:36:30 T:2156 M:1086398464 DEBUG: Load FileBrowser.xml: 2.33ms
20:36:30 T:3764 M:1086390272 DEBUG: thread start, auto delete: 0
20:36:30 T:2156 M:1086386176 DEBUG: Alloc resources: 0.07ms (0.00 ms skin load, 0.05 ms preload)
20:36:30 T:3764 M:1086386176 INFO: Download: http://images.thetvdb.com/banners/_cache...34c5bc.tbn
20:36:30 T:3764 M:1086382080 DEBUG: FileCurl::Open(0210F6F8) http://images.thetvdb.com/banners/_cache...5021-2.jpg
20:36:31 T:3764 M:1086091264 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:31 T:3764 M:1086103552 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:31 T:3764 M:1086103552 DEBUG: FileCurl::Close(0210F6F8) http://images.thetvdb.com/banners/_cache...5021-2.jpg
20:36:31 T:3764 M:1086103552 INFO: Download: http://images.thetvdb.com/banners/fanart...34c5bc.tbn
20:36:31 T:3764 M:1086103552 DEBUG: FileCurl::Open(0210F4CC) http://images.thetvdb.com/banners/fanart...5021-2.jpg
20:36:32 T:3764 M:1086124032 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:32 T:3764 M:1086136320 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:32 T:3764 M:1086136320 DEBUG: FileCurl::Close(0210F4CC) http://images.thetvdb.com/banners/fanart...5021-2.jpg
20:36:32 T:3764 M:1086136320 INFO: Download: http://images.thetvdb.com/banners/_cache...f5d80b.tbn
20:36:32 T:3764 M:1086132224 DEBUG: FileCurl::Open(0210F6F8) http://images.thetvdb.com/banners/_cache...5021-1.jpg
20:36:34 T:3764 M:1086156800 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:34 T:3764 M:1086169088 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:34 T:3764 M:1086169088 DEBUG: FileCurl::Close(0210F6F8) http://images.thetvdb.com/banners/_cache...5021-1.jpg
20:36:34 T:3764 M:1086169088 INFO: Download: http://images.thetvdb.com/banners/fanart...f5d80b.tbn
20:36:34 T:3764 M:1086169088 DEBUG: FileCurl::Open(0210F4CC) http://images.thetvdb.com/banners/fanart...5021-1.jpg
20:36:35 T:3764 M:1086148608 DEBUG: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 52
20:36:35 T:3764 M:1086148608 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
20:36:35 T:3764 M:1086160896 DEBUG: FileCurl::Close(0210F4CC) http://images.thetvdb.com/banners/fanart...5021-1.jpg
20:36:35 T:3764 M:1086160896 DEBUG: Thread 3764 terminating
20:36:36 T:2156 M:1086148608 DEBUG: SDLKeyboard: scancode: 56, sym: 308, unicode: 0, modifier: 1000
20:36:38 T:2156 M:1085775872 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmc/system/ImageLib.dll)
20:36:38 T:2156 M:1085775872 DEBUG: Win32DllLoader::Unload ImageLib.dll
20:36:38 T:2156 M:1085771776 DEBUG: FreeLibrary(MSVCR71.dll) -> 04B07AD8
20:36:38 T:2156 M:1085771776 DEBUG: FreeLibrary(MSVCP71.dll) -> 04B84A90
20:36:38 T:2156 M:1085771776 DEBUG: Win32DllLoader::Unload MSVCP71.dll
20:36:49 T:2156 M:1086476288 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://images.thetvdb.com (easy=054CD008, multi=054AB688)
20:37:05 T:2156 M:1084809216 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://images.thetvdb.com (easy=054B0008, multi=054BCD48)
Refresh the show. Those are old thumb links.
i tried that before and it did nothing but i just tried it again and it worked
never mind it didnt work. it did for one show but not for the rest
Had this problem for a few days, just fixed it, you need to edit the XML file for the TheTVDB.com scraper. essentially open it in notepad and everywhere the file says "images.thetvdb.com" change to "thetvdb.com", they restructured their domain or something and the original link doesnt work. I did this and it fixed the entire problem for me. Hope it works for you.
Edit: Oh, and after you've done that, you'll have to refresh the library to get it all to appear, what I did was to remove the video source and re add it.
This might sound like a dumb question, but where is the xml file for the tvdb located?
Edit: I'm a dummy, I found it
You do NOT need to edit the XML file unless you are running an ancient build.
All new builds come with the XML file just fine.
ancient, like XBMCLive?
apparently I'm having the same problem
I just updated my tvdb.xml with https://xbmc.svn.sourceforge.net/svnroot...o/tvdb.xml and it did not work.
Ancient as in non 9.11 Alpha1, which is the only supported build by this time (apart from the latest stable perhaps, which is sure to have this problem)
Pages: 1 2
