if i would like to refresh the german string definitions, should i go for the one used in camelot alpha 1 or the most recent build i can do?
edit: ok, i should have been reading the stickies.. the one i can grab from the source is the right one (at least that made me change the path in the corresponding wiki entry that still pointed to the old linuxport path
still valid:
furthermore, am i right that - using the translator tool - where there is no english string defintion for a string id that still has one in german, the german one can be removed, too?
Correct. If the english string isn't there, the german one can be removed.
As soon as the strings are finalized for release, we will do an announcement to this effect.
There may well be a bunch of extras going in for various reasons.
Cheers,
Jonathan
jmarshall Wrote:Correct. If the english string isn't there, the german one can be removed.
Cheers,
Jonathan
as always: thanks for your fast response.
as there are already new, still untranslated strings in it, plus i found some errors in it, i'm going to supply an updated version today.
Sure - as you have time, feel free to update and post on trac. You can always update it again if we don't get it in before you've done another update
Cheers,
Jonathan
jmarshall Wrote:Sure - as you have time, feel free to update and post on trac. You can always update it again if we don't get it in before you've done another update
Cheers,
Jonathan
btw: how comes there are string id's inside the standard xbmc language files that are from mediastream (redux?)
looks like a plan to add it to the default skins
edit: patch submitted, see
#7652
There are no strings in the standard strings.xml from any skin (other than perhaps PM3 and PM3.HD)
Nor will there be, as each skin has it's own strings.xml.
jmarshall Wrote:There are no strings in the standard strings.xml from any skin (other than perhaps PM3 and PM3.HD)
yeah, that's what i thought before and got used to. what you don't see when you use the team xbmc translator tool are the comments, so i checked current english strings.xml and found that one
<!-- strings 33000 thru 33999 reserved for common strings used in addons -->
which explains; just still wonder why there are definitions that are typical for mediastream/mediastream redux like "choose your/watch your/configure the"
anyway, i just translated everything that was visible in the tool.
