Full Version: Music - file view
First off, I really liked Confluence until I discovered Alaska.
What a beautiful skin. My gf, who is an interior designer but not tech-savvy, loves the gorgeous interface too.
I just have a small issue, and I didn't find an answer browsing the forum yet.
I wish to use my music in file view, not library. I added my sources and it works fine.
However, each time I go into the Music, it defaults to the Library view and basically shows a white screen because it is empty (which is normal).
I need to manually change it to File View every single time.
Is there something I am missing?
TIA.
It was set to enter the Library but I've changed it now.
Pardon my ignorance but does that mean I need to redownload the skin?
Thanks for the quick reply anyway, great support!
Yes
Alright. Thanks for the support Smile
joebanana Wrote:Pardon my ignorance but does that mean I need to redownload the skin?
Or check the Github link, look at what I've changed to fix it and edit the file yourself.
Hitcher Wrote:Or check the Github link, look at what I've changed to fix it and edit the file yourself.
Definitely what I'm going to do then, quick and efficient.
