My cable company informed me that they are going fully digital to compensate for bandwidth problems. This will speed up my internet and make all my channels digitally encrypted.
I will need a cable card tuner.
Can anyone recommend one other then these?
http://www.ehomeupgrade.com/2008/09/23/c...enter-pcs/
XBMC won't support the card directly. You'll have to use some PVR backend that we end up supporting as a frontend (myth, vdr, tvheadend, etc). Full support is still in a branch and a month or so off of merge. Regardless, you'll have to find a card that's supported by the backend, not XBMC.
Ok. Thanks. Any other non Ati options? I am going to get one, bit I would like a dual tuner. I have not been able to find anything. After seeing my hdhomerun in action I am sure there has to be a cablecard equivalant
Can anyone tell me what will work with MythTV and accepts a cableCARD other then ATI?
The mythtv people probably can.
heh... good idea... how the heck do you use that mailing list? It's set up like a forum, but I can't post.
