Full Version: [Mac 10.6.2] - XBMC 9.11 (svn-26018) won't start-up ...
Background:
I wanted to test Voddler.com, got an invite a few days ago and tried to install it today with out luck.
Read on their page that they use your open (XBMC's) codebase, so naturally i figured if your's will work - there's something wrong with theirs'.
Problem:
Downloaded the latest .dmg from your site and istalled it. But doesn't run. The curious thing is that I do get an Dock Icon and I have two alternatives "XBMC" and "Window" in the menu - "About XBMC" and "Hide" seem to work ... and only way to quit is with "Force Quit".
Console log:
2010-01-10 12:03:31 XBMC[35596] Can't open input server /Library/InputManagers/Inquisitor
2010-01-10 12:03:41 SIMBL Agent[282] warning: failed to get scripting definition from /Applications/XBMC.app; it may not be scriptable.
2010-01-10 12:03:56 XBMC[35596] +[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f70160
2010-01-10 12:03:56 XBMC[35596] Exception raised during posting of notification. Ignored. exception: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f70160' invoked observer method: '*** -[SDLMain applicationDidFinishLaunching:]' observer: 0x1e0a580 notification name: 'NSApplicationDidFinishLaunchingNotification'
2010-01-10 12:03:56 [0x0-0x772772].com.teamxbmc.xbmc[35596] objc[35596]: Class SIMBL is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 12:03:56 [0x0-0x772772].com.teamxbmc.xbmc[35596] objc[35596]: Class SIMBLPlugin is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 12:05:44 com.apple.launchd.peruser.501[206] ([0x0-0x772772].com.teamxbmc.xbmc[35596]) Exited: Killed
2010-01-10 12:30:26 SIMBL Agent[282] warning: failed to get scripting definition from /Applications/XBMC.app; it may not be scriptable.
2010-01-10 12:30:26 [0x0-0x788788].com.teamxbmc.xbmc[35960] objc[35960]: Class SIMBL is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 12:30:26 [0x0-0x788788].com.teamxbmc.xbmc[35960] objc[35960]: Class SIMBLPlugin is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 12:30:26 XBMC[35960] +[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160
2010-01-10 12:30:26 XBMC[35960] Exception raised during posting of notification. Ignored. exception: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160' invoked observer method: '*** -[SDLMain applicationDidFinishLaunching:]' observer: 0x2908450 notification name: 'NSApplicationDidFinishLaunchingNotification'
2010-01-10 12:31:37 com.apple.launchd.peruser.501[206] ([0x0-0x788788].com.teamxbmc.xbmc[35960]) Exited: Killed
2010-01-10 12:59:08 SIMBL Agent[282] warning: failed to get scripting definition from /Applications/XBMC.app; it may not be scriptable.
2010-01-10 12:59:10 [0x0-0x7a27a2].com.teamxbmc.xbmc[36326] objc[36326]: Class SIMBL is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 12:59:10 [0x0-0x7a27a2].com.teamxbmc.xbmc[36326] objc[36326]: Class SIMBLPlugin is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 12:59:10 XBMC[36326] +[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160
2010-01-10 12:59:10 XBMC[36326] Exception raised during posting of notification. Ignored. exception: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160' invoked observer method: '*** -[SDLMain applicationDidFinishLaunching:]' observer: 0x2a06e20 notification name: 'NSApplicationDidFinishLaunchingNotification'
2010-01-10 13:14:04 com.apple.launchd.peruser.501[206] ([0x0-0x7a27a2].com.teamxbmc.xbmc[36326]) Exited: Killed
2010-01-10 13:14:15 SIMBL Agent[282] warning: failed to get scripting definition from /Applications/XBMC.app; it may not be scriptable.
2010-01-10 13:14:15 XBMC[36381] +[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160
2010-01-10 13:14:15 XBMC[36381] Exception raised during posting of notification. Ignored. exception: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160' invoked observer method: '*** -[SDLMain applicationDidFinishLaunching:]' observer: 0x2a0c4f0 notification name: 'NSApplicationDidFinishLaunchingNotification'
2010-01-10 13:14:15 [0x0-0x7a67a6].com.teamxbmc.xbmc[36381] objc[36381]: Class SIMBL is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 13:14:15 [0x0-0x7a67a6].com.teamxbmc.xbmc[36381] objc[36381]: Class SIMBLPlugin is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 13:15:16 com.apple.launchd.peruser.501[206] ([0x0-0x7a67a6].com.teamxbmc.xbmc[36381]) Exited: Killed
2010-01-10 13:21:42 SIMBL Agent[282] warning: failed to get scripting definition from /Applications/XBMC.app; it may not be scriptable.
2010-01-10 13:21:42 [0x0-0x7a97a9].com.teamxbmc.xbmc[36412] objc[36412]: Class SIMBL is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 13:21:42 [0x0-0x7a97a9].com.teamxbmc.xbmc[36412] objc[36412]: Class SIMBLPlugin is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 13:21:42 XBMC[36412] +[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160
2010-01-10 13:21:42 XBMC[36412] Exception raised during posting of notification. Ignored. exception: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160' invoked observer method: '*** -[SDLMain applicationDidFinishLaunching:]' observer: 0x3802160 notification name: 'NSApplicationDidFinishLaunchingNotification'
2010-01-10 13:22:24 com.apple.launchd.peruser.501[206] ([0x0-0x7a97a9].com.teamxbmc.xbmc[36412]) Exited: Killed
2010-01-10 13:22:45 SIMBL Agent[282] warning: failed to get scripting definition from /Applications/XBMC.app; it may not be scriptable.
2010-01-10 13:22:46 XBMC[36421] +[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160
2010-01-10 13:22:46 XBMC[36421] Exception raised during posting of notification. Ignored. exception: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0x1f6a160' invoked observer method: '*** -[SDLMain applicationDidFinishLaunching:]' observer: 0x38048f0 notification name: 'NSApplicationDidFinishLaunchingNotification'
2010-01-10 13:22:46 [0x0-0x7aa7aa].com.teamxbmc.xbmc[36421] objc[36421]: Class SIMBL is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
2010-01-10 13:22:46 [0x0-0x7aa7aa].com.teamxbmc.xbmc[36421] objc[36421]: Class SIMBLPlugin is implemented in both /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL and /Library/ScriptingAdditions/SIMBL.osax/Contents/MacOS/SIMBL. One of the two will be used. Which one is undefined.
guess it's a problem with SIMBL. Might want to try to update that one.
I had the latest installed - but I re-installed it again, and now it works.
