Full Version: [THEME] Confluence Red Color Theme
Decided to get the ball rolling after a user request the other day so here we go
Your going to need a XBMC newer than revision 27233 for this to work because there was a bug in the theme code so stable Camelot build wont work
RED THEME
CLICK TO DOWNLOAD
Extract it to your confluence folder Depending on your platform it may be write protected (Linux)
good job, beautiful Big Grin
it goes with my cap !
is it possible to get the uncompressed files? I'd like to repack them for confluence plex. xbt files are unsupported.
Are there any plans to package this into Confluence by default? If I remember correctly, the default PM3 (back in my XBOX days) eventually came packaged with green, red, and blue versions.
NS
Not really packed by default no because they would increase the xbmc download by ~10% I'm more than happy to put them in as a downloadable addon when it becomes possible to do so
Ah. Mods as add-ons that could be enabled/disabled would be very cool. Thanks for the response!
Are there any screenshots of this?
