Full Version: Xperience1080 (preview & svn)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
Update 2011-08-29: Video of Xperience1080 0.9b
NOTE: SVN is outdated. New version for pre-Eden nightlies will be out on September 1st. (or few days later Big Grin)
Because the old thread is gone because of the data loss, here it is again. And because it will last some time until I can finish the mod, you can try the current version. There are many unfinished things and I'm aware of almost all bugs... best XBMC build to use is #27527, the download is in the Beta Bravo release thread. For OSX you can use #27517.
The project is hosted on googlecode and you can do a svn checkout of the skin with:
svn checkout http://xperience1080.googlecode.com/svn/trunk/ xperience1080
Download (thanks to ppic): http://passion-xbmc.org/downloads/?sa=downfile;id=93
I'll try to finish it as soon as I can but I have more important work to do at the moment so it will not finished within the next 2 months.
Old Thread:
some may noticed that I'm working on a 1080p version of Xperience (posted some screens in the xperience mod help thread). I'll post a download link later on in this thread if everything is done. I think it will last a month or two or maybe longer to get it done because I have not that much time soon.
But I'd like to show some screens and a video of what I've done so far in the past 2 months. There are still bugs and unfinished things, you'll maybe notice some of them in the video... many dialogs are missing but the views are nearly done besides the pic panel and some details / animations. You'll also notice some things of the Surface skin from phyek... XBMCG33K asked me already if I could provide a version without that stuff. Since it would cost much time to change it completly, I'll maybe add different graphics for those elements and put them in an optional xpr... so same function but different look (background, focus images etc.).
To the performance:
The mod will not run well on slow systems with onboard graphics... I have a Pentium E6300 with Geforce 9300 (GT240 or better would be optimal, maybe GT220 is already enough) and it's not running optimal, especially with fanart turned on. On my workstation it's running smooth with a 9600GT.
So here are the video and the images, hope you like it.
Video
Some Screens:
All images are here (I'll add all new images there):
Imageshack Album
Really nice work, Going to test now.
Command: Checkout from http://xperience1080.googlecode.com/svn/trunk/ xperience1080-read-only, revision HEAD, Fully recursive, Externals included
Error: URL 'http://xperience1080.googlecode.com/svn/trunk/%20xperience1080-read-only'
Error: doesn't exist
Finished!:
is the link broken?
my bad...
espengaasemyr Wrote:Command: Checkout from http://xperience1080.googlecode.com/svn/trunk/ xperience1080-read-only, revision HEAD, Fully recursive, Externals included
Finished!:
is the link broken?
my bad...
I have Just tried that my self but i am getting several errors
PROPFIND of '/svn/trunk': Could not read status line: An existing connection was forcibly closed by the remote host. (http://xperience1080.googlecode.com)
Not sure if i am doing something wrong. I may have to resort to downloading each file one by one could take a few day's lol.
Any one else managed to download it yet? any chance of a download link?
Yes that's the url and it should work... "xperience1080-read-only" is the foldername to which the files are downloaded, you can name it as you wish.
The english localize file is now updated.
good, i'll add your repos to xbmc passion skins nightly builds
it will be updated all night.
ppic Wrote:good, i'll add your repos to xbmc passion skins nightly builds
Sod it i will wait untill it's on Passion skins as my conection to http://xperience1080.googlecode.com/svn/trunk/ keeps being forceibly refusedNo
it's ready, you can download it Wink
ppic Wrote:it's ready, you can download it Wink
PPIC not sure what's wrong but i tried to download that file 4 times
The most i got down was 62mb. I run a test on my internet connection at http://netalyzr.icsi.berkeley.edu/
and it shows no problems, oh well am going to stick with the original beta 2 before i tear all my
Hair out. Thanks all the same guys
@ Paul,
I have downloaded several times without problems
I have managed to download this. I tried last night and got a broken zip file, but seems ok now.
I have just downloaded at 700mbs and just going to have a look now.
I'm not sure for why, but just tried the Xperience1080, didn't really like it that much if at all. Tried to go back to Xperience from Team Blackbolt, but now all the graphics are buggered and the squares are missing and showing an avatar picture.
Before this it was working perfectly.
paul Wrote:PPIC not sure what's wrong but i tried to download that file 4 times
that's weird !
ppic Wrote:that's weird !
Too right it's weird, the only other time i ever encountered a problem like this was
when i used to download Aeon_Auriga from Github(when DJH was still around) and the downloads from there would often stop halfway and what you did get was often corrupt.
All i know is theres nothing wrong at my end as the link i gave out earlier is the recommended test site used by 3UK (i'm on mobile modem) so it has to be a problem with the passion site.Confused
