I have Apple TV upgraded to Version 3
I am running XBMC Build Pre 10.5 R28256 Compiled Mar 1 2010
Wired 200mbps Homeplug to
Windows Home Server
I have recently upgraded from Xbox 1 to Apple TV and noticed there is a massive delay when playing DVD ISO's whereas my Xbox1 plays them instantly.
The appletv is set to 720p, and I have included the advancedsettings.xml in the userdata directory for the statfiles. I read somewhere that it may help.
I have also copied one iso into another folder to see if that sped things up but it didnt. I am not sure how to post a log, so bear with me if you need that information too.
Someone please help, because at present the appletv doesnt appear to be the step up I had hoped for.
Many thanks
Alex
see my sig on how to get xbmc.log
libdvdnav/libdvdread seems to take a long time retrieving the dvd key when packed up in an ISO. Not sure why. It would be interesting to see if a dvd outside of the ISO takes the same amount of time. Also if the ISO is on the local disk rather than an SMB share.
Davilla, what do you mean by a dvd outside of the ISO?
I am currently uploading an ISO to AppleTV so I can repost the log.
The weird thing is it only happens when it first reads the disk. After it has played once, the DVD iso loads up almost immediately.
Alex
For what it's worth, I have the exact same load time issues with ISOs.
If I unpack the ISO into its component DVD files - .ts .vob .ifo etc. - =then it loads as quick as an AVI.
My Media files are stored on a Vista (i know) PC and accessed vie 100Meg Ethernet.
i have not tried it with the files locally on the ATV.
Must4rd Wrote:Davilla, what do you mean by a dvd outside of the ISO?
Alex
libdvdnav/libdvdread will cache the DVD key once it's found. You can see that in the logs.
Mount the IOS, take the all the items inside and place them in a new folder. The DVD contents are now "outside" the ISO.
Think of an iso as a bucket. Inside the iso is a VIDEO_TS folder and maybe an AUDIO_TS folder.
Until now I thought it is normal when XBMC needs longer to load DVD content than it takes to play mkv-files for instance.
Loading the DVD menu takes about 12 sec. here, another approx. 15 seconds to start the main movie., regardless whether it's an ISO or a folder containing the Video_TS files.
All movie content is stored on a NAS with Samba shares.
Davilla, could you please take a look at my xbmc.log:
http://pastebin.com/L9hVBjju
Thank you and kind regards,
Bobby
I have copied an ISO to the hdd in the apple tv and it started instantly. It must be an issue with the network.
Is there anything else I can look at. If I plug in the xbox 1 the DVD ISO loads very quickly.
Are you connecting over ethernet or Wifi?
Sorry I did not see the homeplug. You will know that those are actually real 85 mbps not 200
If it is a network buffering issue you can try with the network tweak
http://wiki.awkwardtv.org/wiki/Network_Tweaks
It's definitely a network issue in my case, but the network tweak had no effect unfortunately. My apple TV is connected over ethernet.
Any more suggestions?
The weird thing is it all works fine on my xbox1. The delay launching an iso can be as long as 3 minutes. I have very little or no delay on my xbox.
I just cant fathom it out
Hello,
Im having the same issue. DVDISOs take up to 20minutes to start playing. However when i just have the Folder structure it plays instantly.
Hope this will be fixed. I'm playing my files from a 100mbit NAS.
xploid Wrote:Hello,
pastebin xbmc.log. it's the only way we can "see" what is happening since we are not by your side and that damm crystal ball stopped working.
