Could someone point me in the right direction to add the Apple Movie Trailers script to the home page on the Back-Row skin.
thanks
andy
Sure just make sure you install the Apple Movie Trailers plugin - in the example below I've used the Apple Movie Trailers Lite version.
Once you've installed it set up the shortcut in the skin options as below:
thanks Sharpe for the response i have done the above but the shortcut still does not appear in the Home Page
Make sure you tick the little box on the right
yep confirmed that is ticked, screen looks just like your screenshot now - i did have the smaller home strip in home menu option ticked but removed that and still does not show
Oh that's strange then - providing you activate the box to the right of the home label (as in the screen shot) then that should cause an extra box to appear in the home screen.
Make sure that you are using an up to date home.xml in the 720p folder and not a modded version of it.
