2010-05-13, 17:26
I have a few basic questions about creating a skin that is 1080p. I have looked at the very few that are out there and just want to see what is needed to go in that direction.
-Skin folder is 1080i? Is this needed rather than having it labeled 720p? Can you have both?
-Does the default resolution need to be changed in the skin.xml?
-Textures should also be created with a higher resolution?
-In terms of skinning, what size should be used for backgrounds and fullscreen images (height & width). Does this matter if you have already skinned using the standard 720p or do you need to go through your files and make height and width adjustments?
Sorry if I seem a little dense on the subject. Resolutions are a knowledgable area for me. Much thanks to anyone who can help or offer up suggestions.
