Full Version: [BUGS] and missing items
Bump title on 'Episode' view up a few pixels
Try changing wall size
more infolabels for launcher
AMT litle specific views - Poster/Showcase/Wall
select a bookmark the selected one disappears
I just set all the backdrops for the different sections. But I just couldn't get the one for "Shutdown" working until I noticed that whenever I change the backdrop for "Shutdown" it changes the backdrop for "Settings" instead.
Furthermore "Weather" backdrop can be set but it does neither appear when I move to "Weather" in the main menu nor when I activate it to see the actual weather data.
not sure if this should go in here, but there isn't any way to determine if a show has any unwatched items or not from the landscape view, unless you navigate into the season level of the show.
feerlessleadr Wrote:not sure if this should go in here, but there isn't any way to determine if a show has any unwatched items or not from the landscape view, unless you navigate into the season level of the show.
Well my theory was the logos were just too pretty to have a strike through going through them...
Montellese Wrote:I just set all the backdrops for the different sections. But I just couldn't get the one for "Shutdown" working until I noticed that whenever I change the backdrop for "Shutdown" it changes the backdrop for "Settings" instead.
1. I probably copied the settings code but forgot to change it to the correct setting
2. Weather Fanart works, I forgot to code a seperate way for just regular fanart
Saw 2 little things Smile
Mpaa is overlapping cover DialogVideoInfo
Rss feed goes over Cover/CdArt Now Playing Homescreen
There is actually no way to reboot or change session. You may want to add a shutdown submenu with these items.
Waffa, i also saw that but only in 16:10 in 16:9 i didn't.
Extra Option (Toggle):
An Option to disable the zoom-out transition while scrolling in file-view (movies).
Regards,
ubuntuf4n
xbs08 Wrote:Waffa, i also saw that but only in 16:10 in 16:9 i didn't.
My res is 1280x720 (16:9) Nod
Ok
I just check it and depends on the poster width.
In movie info - get thumb and get fanart the rss feed scrolls over the buttons.
xbs08 Wrote:Ok
Thx for 2x checking, personally I never noticed...I really only want RSS on home so I look into that...
In music I see only 'Jukebox' and 'Files'. Is that correct, or is showcase supposed to be available here as well?
Edit: No issue
mcborzu Wrote:Well my theory was the logos were just too pretty to have a strike through going through them...
i figured it was something like that Big Grin
would it be possible to add some sort of indicator that there are watched episodes? i don't think it necessarily needs to be a strikethrough, but perhaps something that says 'x unwatched episodes' or something like that
Thanks for the great skin!
First I must say Great Skin. Never mind figured it out.
Montellese Wrote:Furthermore "Weather" backdrop can be set but it does neither appear when I move to "Weather" in the main menu nor when I activate it to see the actual weather data.
would anyone like to let me know the naming convention or how to get weather fanart working.
