I might be a little late, but is there another download repository for this plugin? The link seems to be broken at this time.
I can not download the plugin
Anonym Wrote:I can not download the plugin
This plugin is discontinued and it doesn't work with the current version of xbmc.
Also the download link is probably broken.
I uploaded yesterday a service for subtitrari.regielive.ro. Should be available as soon as the xbmc.subtitles plugin pushes a new version.
Features:
* supports movies and TVShows
* retrieves the rating
* marks as "sync" the subtitles that have same name as the movie file (therefore it works very well when we preserve the movie name as it was released)
* shows if a movie is a 1 or n CD movie
* sorts results first by "sync" and then by rating
Congratulations!
But how did you managed to implement it, because this site has two results pages, first with movies which correspond to the search, and a the second page with subitles correponding to the option of the previous page. And subtitlesOSD has only one result page.
Subs.ro and titrari.ro are much easier to implement. But good for you.
Can't wait to test your service.
Yeah, good point... For now it aggregates all results. This should get better once I use the "year" also during the filtering (for now it is not implemented). I quickly checked subs.ro but there's such a mess inside the downloaded .zip
I use now regielive.ro daily (manually) and I got used with their clean concept of naming subs and keeping one zip for a subtitle set.
Just a small update: I added the year-based filtering and it should reduce traffic/results and improve accuracy.
Another idea that could help improving accuracy would be to add a flag in "Options" for this service that toggles between "Sort found movies by relevance" and "Sort found movies by year"....
Working fine, thanks so much ThumbGen
Unfortunately the service is broken (they implemented a "protection" on their side). I'm trying to fix in the next days.
The service works again. Protection was removed on server side but I am preparing myself for it to come back
