Full Version: XBMC no sound
I've searched and searched and have quite literally reinstalled xbmc 8 times trying different guides. I officially give up and ask for help :mad:.
I'm using XBMC Live 9.11 installed to my hard drive.
I have an a8n sli-deluxe with onboard sound and a audigy 2 zs. The onboard sound (analog 5.1) will be used to squeezebox and the audigy (digital 5.1) goes to my a/v receiver from xbmc. The receiver is capable of ac3/dts and if I disable the onboard sound and use plughw to specify the audigy, everything works.
However, disabling my onboard sound is not an option since the audigy goes crazy if I use both the analog and digital for two separate things at the same time. So, to use both xbmc and squeezebox at the same time, I need two audio devices.
Currently I have a nice fresh install but I added the following three lines to the end of /etc/modprobe.d/alsa-base.conf to force the order of the cards.
options snd_emu10k1 index=0
options snd_mpu401 index=1
options snd_intel8x0 index=2
Current config:
Audio output: digital
ac3: y
dts: y
Audio output device: default
passthrough: iec958
downmix: n
debug logging: true
reboot
Tests:
x264 dolby digital - 5.1 passed correctly
xvid dolby digital - 5.1 passed correctly
xvid mp3 - no sound, receiver still is seeing 5.1 (incorrect) but no actual audio
x264 dts - 5.1 passed correctly
xvid ac3 - stereo passed correctly
x264 ac3 - 5.1 passed correctly
xvid mp3 - no sound, but receiver is seeing stereo (correct)
vc1 wmapro - no sound, receiver sees stereo (incorrect)
flac stereo - no sound
mp3 stereo - no sound
no navigation sounds
Now, what is really odd. I go disable debugging and try to replay a x264 dts sample and I get failure to initialize audio device.... ?!
Any help resolving these oddities? Obviously I don't want to have debugging on at all times while trying to use xbmc and I do want to be able to play music at times. I can attach any debug logs as well, but one for each sample seemed a bit excessive.
Thanks!!!
In the meantime I setup squeezeslave and it plays perfectly over the audigy 2 analog. So I attempted to make xbmc play over the nvidia onboard.
Audio output device: nvidia ck804 default.
Reboot
I have navigation and music, but over the audigy2 analog lines and NOT the onboard digital. What gives?
aplay -l shows nvidia looking like
card 2: CK804 [NVidia CK804], device 0: Intel ICH [NVidia CK804]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 2: CK804 [NVidia CK804], device 2: Intel ICH - IEC958 [NVidia CK804 - IEC958]
  Subdevices: 1/1
so I attempt
audio output device: custom plughw:2,2
passthrough output device: custom plughw:2,2
reboot.
navigation sounds through the audigy analog, but no other sound......
xbmc.log shows that it never finds plughw:2,2 so it goes to default which I can only assume is the nvidia analog since I don't get the audio device not initialized error and the audigy analog plays nothing.
Any help?
interestingly I have a similar board the a8n sli. I have intermittent sound problems, trying to track them down before I reported them.
It "seems" if i have the tv on a different channel and start up xbmc sometimes i have no sound.
I'm getting nowhere with this...
Any help?
post your xbmc.log file
xbmc@XBMCLive:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Audigy2 [SB Audigy 2 [Unknown]], device 0: emu10k1 [ADC Capture/Standard PCM Playback]
  Subdevices: 32/32
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
  Subdevice #8: subdevice #8
  Subdevice #9: subdevice #9
  Subdevice #10: subdevice #10
  Subdevice #11: subdevice #11
  Subdevice #12: subdevice #12
  Subdevice #13: subdevice #13
  Subdevice #14: subdevice #14
  Subdevice #15: subdevice #15
  Subdevice #16: subdevice #16
  Subdevice #17: subdevice #17
  Subdevice #18: subdevice #18
  Subdevice #19: subdevice #19
  Subdevice #20: subdevice #20
  Subdevice #21: subdevice #21
  Subdevice #22: subdevice #22
  Subdevice #23: subdevice #23
  Subdevice #24: subdevice #24
  Subdevice #25: subdevice #25
  Subdevice #26: subdevice #26
  Subdevice #27: subdevice #27
  Subdevice #28: subdevice #28
  Subdevice #29: subdevice #29
  Subdevice #30: subdevice #30
  Subdevice #31: subdevice #31
card 0: Audigy2 [SB Audigy 2 [Unknown]], device 2: emu10k1 efx [Multichannel Capture/PT Playback]
  Subdevices: 8/8
card 0: Audigy2 [SB Audigy 2 [Unknown]], device 3: emu10k1 [Multichannel Playback]
  Subdevices: 1/1
card 0: Audigy2 [SB Audigy 2 [Unknown]], device 4: p16v [p16v]
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
xbmc@XBMCLive:~$ aplay -L
front:CARD=Audigy2,DEV=0
    SB Audigy 2 [Unknown], ADC Capture/Standard PCM Playback
    Front speakers
rear:CARD=Audigy2,DEV=0
    Rear speakers
center_lfe:CARD=Audigy2,DEV=0
    Center and Subwoofer speakers
side:CARD=Audigy2,DEV=0
    Side speakers
surround40:CARD=Audigy2,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Audigy2,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Audigy2,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Audigy2,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Audigy2,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Audigy2,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
null
    Discard all samples (playback) or generate zero samples (capture)
audio output: digital
audio output device: nvidia ck804 default
passthrough: custom plughw:2,2
xbmc.log
13:53:01 T:2949581680 M:1885339648    INFO: ffmpeg[AFCF0B70]: Input #0, matroska, from '/media/raid/Video/test.mkv':
13:53:01 T:2949581680 M:1885339648    INFO: ffmpeg[AFCF0B70]:   Duration: 00:19:50.88, start: 0.000000, bitrate: N/A
13:53:01 T:2949581680 M:1885339648    INFO: ffmpeg[AFCF0B70]:     Stream #0.0: Audio: ac3, 48000 Hz, 6 channels, s16
13:53:01 T:2949581680 M:1885339648    INFO: ffmpeg[AFCF0B70]:     Stream #0.1(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 tbr, 1k tbn, 47.95 tbc
13:53:01 T:2949581680 M:1885339648  NOTICE: Opening video stream: 1 source: 256
13:53:01 T:2949581680 M:1885339648  NOTICE: Creating video codec with codec id: 28
13:53:01 T:2949581680 M:1885339648   DEBUG: FactoryCodec - Video:  - Opening
13:53:01 T:2949581680 M:1885339648   DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/swscale-0.6.1-i486-linux.so
13:53:01 T:2949581680 M:1885093888  NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1280x720)
13:53:01 T:2949581680 M:1884372992  NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
13:53:01 T:2949581680 M:1884372992  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (VDPAU acceleration)
13:53:01 T:2949581680 M:1884372992   DEBUG: FactoryCodec - Video: ff-h264_vdpau - Opened
13:53:01 T:2949581680 M:1884372992  NOTICE: Creating video thread
13:53:01 T:2939091824 M:1884332032   DEBUG: thread start, auto delete: 0
13:53:01 T:2939091824 M:1884332032   DEBUG: LinuxRendererGL: Cleaning up GL resources
13:53:01 T:2939091824 M:1884332032   ERROR: (VDPAU) ReleasePixmap called without valid pixmap
13:53:01 T:2939091824 M:1884332032  NOTICE: running thread: video_thread
13:53:01 T:2949581680 M:1884332032  NOTICE: Opening audio stream: 0 source: 256
13:53:01 T:2949581680 M:1884332032  NOTICE: Finding audio codec for: 86020
13:53:01 T:2949581680 M:1884332032   DEBUG: FactoryCodec - Audio: passthrough - Opening
13:53:01 T:2949581680 M:1884332032   DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/liba52-i486-linux.so
13:53:02 T:2949581680 M:1884397568   DEBUG: FactoryCodec - Audio: passthrough - Opened
13:53:02 T:2949581680 M:1884397568  NOTICE: Creating audio thread
13:53:02 T:2928601968 M:1884397568   DEBUG: thread start, auto delete: 0
13:53:02 T:2928601968 M:1884397568  NOTICE: running thread: CDVDPlayerAudio::Process()
13:53:02 T:2949581680 M:1884397568   DEBUG: ReadEditDecisionLists - checking for any edit decision lists (EDL) on local drive or remote share for: /media/raid/Video/test.mkv
13:53:02 T:2949581680 M:1884397568    INFO: Loading skin file: DialogProgress.xml
13:53:02 T:3078731648 M:1884397568   DEBUG: CGUIAudioManager::DeInitialize
13:53:02 T:3078731648 M:1884397568   DEBUG: OnPlayBackStarted - Playback has started
13:53:02 T:3078731648 M:1880027136   DEBUG: CGUIInfoManager::SetCurrentMovie(/media/raid/Video/test.mkv)
13:53:10 T:3078731648 M:1880076288    INFO: CheckIdle - Closing session to http://feeds.feedburner.com (easy=0x98e0208, multi=0x9852658)
13:53:10 T:3078731648 M:1880076288    INFO: CheckIdle - Closing session to http://xoap.weather.com (easy=0xb2308240, multi=0xb23019b8)
13:53:30 T:2989489008 M:1879826432   DEBUG: Thread 2989489008 terminating (autodelete)
13:53:30 T:3004402544 M:1879953408   DEBUG: Thread 3004402544 terminating (autodelete)
13:53:31 T:3078731648 M:1879949312   DEBUG: SECTION:UnloadDelayed(SECTION: LCODE)
13:53:32 T:3078731648 M:1879949312   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmc/system/ImageLib-i486-linux.so)
13:53:32 T:3078731648 M:1879949312   DEBUG: Unloading: ImageLib-i486-linux.so
13:53:38 T:2960071536 M:1879965696    INFO: Loading skin file: DialogProgress.xml
13:53:38 T:2960071536 M:1879965696   DEBUG: Load DialogProgress.xml: 1.53ms
13:53:38 T:2960071536 M:1879965696   DEBUG: ------ Window Init (DialogProgress.xml) ------
13:53:38 T:2960071536 M:1879965696   DEBUG: Alloc resources: 0.03ms (0.00 ms skin load)
13:53:38 T:2949581680 M:1879965696   DEBUG: Load DialogProgress.xml: 36585.69ms
13:53:38 T:2928601968 M:1880109056   DEBUG: ParseFrame - source flags changed flags:17 sr:48000 br:384000
13:53:38 T:2928601968 M:1879126016  NOTICE: Creating audio device with codec id: 86020, channels: 2, sample rate: 48000, pass-through
13:53:38 T:2928601968 M:1879126016    INFO: AudioRendererFactory:  not a explicit device, trying to autodetect.
13:53:38 T:2928601968 M:1879126016   DEBUG: PulseAudio: Opening Channels: 2 - SampleRate: 48000 - SampleBit: 16 - Resample false - Codec AC3 - IsMusic false - IsPassthrough true - device: plughw:2,2
13:53:38 T:2928601968 M:1879126016   DEBUG: RemoveActiveDevice - Removing device 1
13:53:38 T:2928601968 M:1879126016   DEBUG: SetActiveDevice - SetActiveDevice from 0 to 2
13:53:38 T:2928601968 M:1879126016   DEBUG: RemoveActiveDevice - Removing device 0
13:53:38 T:2928601968 M:1879126016 WARNING: PulseAudio: Does not support passthrough
13:53:38 T:2928601968 M:1879126016   DEBUG: SetActiveDevice - SetActiveDevice from 2 to 1
13:53:38 T:2928601968 M:1879126016   DEBUG: RemoveActiveDevice - Removing device 2
13:53:38 T:2928601968 M:1879126016   DEBUG: CALSADirectSound::CALSADirectSound - Channels: 2 - SampleRate: 48000 - SampleBit: 16 - Resample false - Codec AC3 - IsMusic false - IsPassthrough true - audioDevice: plughw:2,2
13:53:38 T:2928601968 M:1879126016   DEBUG: Initialize - using alsa device plughw:2,2:AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2
13:53:38 T:2928601968 M:1879126016   ERROR: Initialize - failed to open custom device plughw:2,2:AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2, retry with default plughw:2,2
13:53:38 T:2939091824 M:1879130112   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
13:53:38 T:3078731648 M:1879130112    INFO: initializing python engine.
another day and I'm getting no success.
I'm trying various options in asoundconf and asoundrc but nothing yet.
I decided to start with the basics.
I disconnected the audigy and went with the coax spdif on the a8n. With xbmc not running there is no lock on the receiver which is to be expected. As xbmc starts however, there is still no pcm lock.
card 0: CK804 [NVidia CK804], device 0: Intel ICH [NVidia CK804]
  Subdevices: 0/1
card 0: CK804 [NVidia CK804], device 2: Intel ICH - IEC958 [NVidia CK804 - IEC958]
  Subdevices: 1/1
default:CARD=CK804
    NVidia CK804, NVidia CK804
    Default Audio Device
front:CARD=CK804,DEV=0
    Front speakers
surround40:CARD=CK804,DEV=0
surround41:CARD=CK804,DEV=0
surround50:CARD=CK804,DEV=0
surround51:CARD=CK804,DEV=0
surround71:CARD=CK804,DEV=0
iec958:CARD=CK804,DEV=0
    NVidia CK804, NVidia CK804 - IEC958
null
mplayer -vo null -ao alsa:device=iec958 Prelude.wav
causes the receiver to immediately lock on pcm, but no sound to play. I'm starting to think that alsa is fubar.
Any ideas?
I set the audio output device to default and the passthrough to custom plughw:0,0. I now get sound for anything that requires passthrough but no music, movies encoded with mp3, and no system sounds.
If I set the default audio device to the plughw:0,0 mp3 and non-passthrough still doesn't play and the receiver doesn't lock. Passthrough content still plays
12:13:54 T:1591085936 M:1844424704 DEBUG: SetActiveDevice - SetActiveDevice from 0 to 2
12:13:54 T:1591085936 M:1844424704 DEBUG: RemoveActiveDevice - Removing device 0
12:13:54 T:1591085936 M:1844424704 DEBUG: Initialize - using alsa device plughw:0,0
12:13:54 T:1591085936 M:1844424704 DEBUG: CALSADirectSound::Initialize - packet size:2048, packet count:16, buffer size:8202
12:13:54 T:1591085936 M:1844424704 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
12:13:54 T:1591085936 M:1844424704 DEBUG: CDVDPlayerAudio:: Discontinuty - was:2460924732.623878, should be:2460918790.173653, error:-5942.450225
is in the log. What is the discontinuty error?
bump.
Trying to solve I get no sound with mp3 encoding and no navigation sounds.
midna Wrote:bump.
still haven't gotten this although passthrough audio works consistently.
Ok, I started over AGAIN.
xbmc live installed to hard drive.
I'm using the audigy card and while:
mplayer -vo null -ac hwac3,hwdts -ao alsa:device=iec958 /media/raid/Video/TV/sample.mkv
works perfectly xbmc does not
My sound is going out the audigy2 digital coax to a receiver.
Sound settings:
digital
ac3 checked
dts checked
audio output iec958
custom passthrough iec958
downmix unchecked
aplay -l
  Subdevices: 31/32
  Subdevices: 8/8
  Subdevices: 1/1
  Subdevices: 1/1
aplay -L
    Front speakers
    Rear speakers
    Side speakers
null
And I get a bunch of audio device cannot be initialized messages when testing.
I go ahead and reboot.
Everything is playing PERFECTLY!! Awesome!!!! So I start to edit this post and disable the debugging. I try to watch something that literally worked right before disabling debugging, and I get the same damn audio device cannot be initialized message. My neighbors had to have heard my cursing at the tv.
Navigation sounds still work crazily enough...
So I try to reboot again, maybe the craziness will repeat and I just won't enable debugging.....
Guess what, it works again.... WHAT?!
Why would it stop working as soon as debugging is disabled?!!?!?!? It's like it's taunting me.....
Either way, it's working now, next step is to re-enable the onboard sound. But first i'm taking a system backup in case things go south for some unknown reason....
Do you have any updates on this issue?
The solution for your onboard card was:
Set audio and pass-through to 'custom'
Type in "surround51:CARD=CK804,DEV=0" for audio device and pass-through.
The reason is that analog and digital is intern connected.
Maybe by translating it to you Audigy2 it will work to.
