Gentlemen,
I am in a hurry, very busy, so I can't write much right now...
Images:
Links:
[url=http://"http://fancyxbox.info/xtras/xtv/xtv_cospefogo_2010-06-02.rar"]SKIN XTV COSPEFOGO (2010-06-02)[/url]
[url=http://"http://fancyxbox.info/xtras/xtv/atalhos_visuais.rar"]MAME Shortcuts (.CUTs)[/url]
Tips:
To have the EMULATORS and the ARCADES home buttons working correctly, you need to have the following structure on your F:
F:/emulators
----- You console emulators, NES, SNES, Genesis
F:/arcades
----- CoinOps, Final Burn, MameoX128, etc
Maybe you will need to add the sources in the MY-PROGRAMS section.
Also, maybe you will need to edit the HOME.XML for something else.
I am in a hurry now. It's not complex.
You guys can figure it out.
XBMC manual is right out there.
Tips for the MAME Shortcuts
Bulk edit my .CUTS with some program like Dreamweaver to point to corrent image folder locations, different from mine, of course.
And, enjoy!
Last images:
That's it!
AHHHHHHHHHHHHHH
EXCLUSIVE FOR 480p/480i.
I don't know its behavior on 720p.
I don't plan to migrate to LCD soon.
Cheers!
Cospefogo.
i would love to try this but links are bad
Ooops!
Correct links are:
http//fancyxbox.info/xtras/xtv/xtv_cospefogo_2010-06-02.rar
http//fancyxbox.info/xtras/xtv/atalhos_visuais.rar
Sorry!
Oops again...
I forgot to mention - Since we don't have Ellipsis for 480p, I decided to use a kind of Ellipsis background on my xTV custom.
Regards,
Cospefogo.
thanks i will give it a try!!!like how it looks!!
i keep getting an error...The requested URL //fancyxbox.info/xtras/xtv/xtv_cospefogo_2010-06-02.rar was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request...ohwell ill keep trying and checking here
i went to the link that was an actual clickable link and it started downloading,,,but the other two links that were typed out give the above error
i just tried to the one i got to download....looks great but i see there is no option for tv shows on home screen..and i was removing sources from the applications,consoles,and one other now games are gone from xbox games....it will not allow me to add sources...this is log from xbmc...sorry so long but i have no idea how else to do it?
10:00:28 M: 57065472 NOTICE: Starting XBMC4Xbox. Built on Apr 27 2010 (SVN:29407, compiler 1310)
10:00:28 M: 57065472 NOTICE: special://xbmc/ is mapped to: Q:\
10:00:28 M: 57065472 NOTICE: special://masterprofile/ is mapped to: q:\UserData
10:00:28 M: 57065472 NOTICE: special://home/ is mapped to: Q:\
10:00:28 M: 57065472 NOTICE: special://temp/ is mapped to: Z:\
10:00:28 M: 57065472 NOTICE: The executable running is: E:\dashboard\default.xbe
10:00:28 M: 57065472 NOTICE: Log File is located: Q:\xbmc.log
10:00:28 M: 57065472 NOTICE: -----------------------------------------------------------------------
10:00:28 M: 57065472 NOTICE: Unmapped drive T
10:00:28 M: 57065472 NOTICE: Mapping drive T to Harddisk0\Partition1\dashboard\UserData
10:00:28 M: 57065472 NOTICE: Setup DirectX
10:00:28 M: 57036800 NOTICE: Mapping drive C to Harddisk0\Partition2
10:00:28 M: 57036800 NOTICE: Mapping drive E to Harddisk0\Partition1
10:00:28 M: 57036800 NOTICE: Unmapped drive D
10:00:28 M: 57036800 NOTICE: Mapping drive D to Cdrom0
10:00:29 M: 57036800 NOTICE: Mapping drive F to Harddisk0\Partition6
10:00:29 M: 57036800 NOTICE: Mapping drive X to Harddisk0\Partition3
10:00:29 M: 57036800 NOTICE: Mapping drive Y to Harddisk0\Partition4
10:00:29 M: 57036800 NOTICE: Unmapped drive Z
10:00:29 M: 57036800 NOTICE: Mapping drive Z to Harddisk0\Partition5
10:00:29 M: 57036800 NOTICE: load settings...
10:00:29 M: 57036800 NOTICE: Mapping drive P to Harddisk0\Partition1\dashboard\UserData
10:00:29 M: 57036800 NOTICE: special://profile/ is mapped to: q:\UserData
10:00:29 M: 57036800 NOTICE: loading special://masterprofile/guisettings.xml
10:00:29 M: 56827904 NOTICE: Getting hardware information now...
10:00:29 M: 56827904 NOTICE: Checking resolution 10
10:00:29 M: 56827904 NOTICE: Setting autoresolution mode 4
10:00:29 M: 56827904 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:00:30 M: 56827904 NOTICE: Loaded playercorefactory configuration
10:00:30 M: 56807424 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:00:30 M: 56807424 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:00:30 M: 56807424 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
10:00:30 M: 56807424 NOTICE: Default Video Player: mplayer
10:00:30 M: 56807424 NOTICE: Default Audio Player: paplayer
10:00:30 M: 56807424 NOTICE: Per AV pack settings are off
10:00:30 M: 56975360 NOTICE: q:\UserData\sources.xml
10:00:30 M: 50458624 NOTICE: Network: Using dashboard IP settings
10:00:30 M: 50126848 NOTICE: Checking the Date!
10:00:30 M: 50126848 NOTICE: start dvd mediatype detection
10:00:30 M: 50061312 NOTICE: initializing playlistplayer
10:00:30 M: 50061312 NOTICE: DONE initializing playlistplayer
10:00:30 M: 50061312 NOTICE: setting fanspeed
10:00:31 M: 50053120 NOTICE: load default skin:[xTV Cospefogo]
10:00:31 M: 48308224 WARNING: Skin has invalid include: contentpanelslide
10:00:31 M: 48287744 WARNING: Skin has invalid include: contentpanelslide
10:00:31 M: 45817856 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
10:00:31 M: 45768704 ERROR: Control 402 in window 10133 has been asked to focus, but it can't
10:00:32 M: 45211648 NOTICE: CApplication::UpdateLibraries - Starting music library startup scan
10:00:32 M: 45133824 ERROR: Control 402 in window 10112 has been asked to focus, but it can't
10:00:32 M: 44535808 NOTICE: initialize done
10:00:32 M: 44494848 NOTICE: Running the application...
10:00:32 M: 44015616 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
10:00:32 M: 44511232 WARNING: CFileFactory::CreateLoader - Unsupported protocol smb
10:00:33 M: 44380160 NOTICE: XBFileZilla: Starting...
10:00:33 M: 44294144 NOTICE: ES: Starting event server
10:00:33 M: 43241472 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
10:00:33 M: 42520576 NOTICE: UDP: Listening on port 9777
10:00:33 M: 41836544 NOTICE: XBFileZilla: Started
10:00:33 M: 42430464 NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:01
10:00:39 M: 44032000 WARNING: CUtil::GetMatchingSource... no matching source found for [Games]
10:00:39 M: 44032000 ERROR: Failed! Destination parameter (Games) does not match a valid source!
10:00:39 M: 43610112 WARNING: Skin has invalid include: contentpanelslide
10:00:39 M: 43589632 WARNING: Skin has invalid include: contentpanelslide
10:00:41 M: 43487232 WARNING: CFileFactory::CreateLoader - Unsupported protocol plugin
10:00:53 M: 45563904 WARNING: Skin has invalid include: contentpanelslide
10:00:53 M: 45543424 WARNING: Skin has invalid include: contentpanelslide
10:00:55 M: 45445120 WARNING: CUtil::GetMatchingSource... no matching source found for [Applications]
10:00:55 M: 45445120 ERROR: Failed! Destination parameter (Applications) does not match a valid source!
10:00:55 M: 45146112 WARNING: Skin has invalid include: contentpanelslide
10:00:55 M: 45125632 WARNING: Skin has invalid include: contentpanelslide
10:00:58 M: 45535232 WARNING: Skin has invalid include: contentpanelslide
10:00:59 M: 45445120 WARNING: CUtil::GetMatchingSource... no matching source found for [Arcades]
10:00:59 M: 45445120 ERROR: Failed! Destination parameter (Arcades) does not match a valid source!
10:00:59 M: 45146112 WARNING: Skin has invalid include: contentpanelslide
10:00:59 M: 45125632 WARNING: Skin has invalid include: contentpanelslide
10:01:07 M: 45522944 WARNING: Skin has invalid include: contentpanelslide
10:01:29 M: 45412352 WARNING: Skin has invalid include: contentpanelslide
10:01:31 M: 45531136 WARNING: Skin has invalid include: contentpanelslide
10:01:35 M: 45527040 WARNING: Skin has invalid include: contentpanelslide
10:01:36 M: 43851776 WARNING: Skin has invalid include: contentpanelslide
10:01:38 M: 43708416 NOTICE: HDD: SMART is supported.
10:01:38 M: 43708416 NOTICE: HDD: SMART is enabled.
10:01:40 M: 45457408 WARNING: Skin has invalid include: contentpanelslide
10:01:45 M: 45461504 WARNING: Skin has invalid include: contentpanelslide
10:01:46 M: 45461504 WARNING: Skin has invalid include: contentpanelslide
10:01:53 M: 45056000 WARNING: Skin has invalid include: contentpanelslide
10:01:53 M: 45035520 WARNING: Skin has invalid include: contentpanelslide
10:01:59 M: 44298240 WARNING: Skin has invalid include: contentpanelslide
10:02:02 M: 44257280 WARNING: CUtil::GetMatchingSource... no matching source found for [Games]
10:02:02 M: 44257280 ERROR: Failed! Destination parameter (Games) does not match a valid source!
10:02:02 M: 44257280 WARNING: Skin has invalid include: contentpanelslide
10:02:12 M: 44343296 WARNING: Skin has invalid include: contentpanelslide
10:02:14 M: 44257280 WARNING: CUtil::GetMatchingSource... no matching source found for [Applications]
10:02:14 M: 44257280 ERROR: Failed! Destination parameter (Applications) does not match a valid source!
10:02:14 M: 44257280 WARNING: Skin has invalid include: contentpanelslide
10:02:20 M: 44351488 WARNING: Skin has invalid include: contentpanelslide
10:02:21 M: 44261376 WARNING: Skin has invalid include: contentpanelslide
10:02:26 M: 44015616 WARNING: Skin has invalid include: contentpanelslide
i dont either am going to delete and try again..maybe bad transfer,and yes im using on xbox
Hey Johnscrub!
I use to add sources pressing WHITE button - using the option on the context menu.
About the TV Shows on home --- Go to the skin settings and you will see some options to show "things" on home. Since I was not planning previously to release this skin to the public, I simply hacked some stuff just for my use.
It I am not wrong, one of the option bring back the TV shows.
OR --- You can go to the PAL folder (inside the skin) and use the original HOME.XML. Just rename the current to something else and rename the backup I left there back to HOME.XML.
Bingo!
Cheers,
Cospefogo.
PS. You can reconfigure the key to get screenshots somewhere else in XBMC files - inside your profile folder. Also, you can manually edit your sources there too.
thanks!!!great mod though !!i will play with it and get it to where i need it..
