Pages: 1 2 3 4 5 6 7 8 9 10 11 12
I'm going to hold off on my mod, just to see what you have in store...
Add-on compatible version now ready.
See first port for install instructions.
Great work (as always
) thanks a lot
PS
Is this Alaska or Alaska revisited? Title says Alaska, the first post mentions Alaska revisited
Copy and paste - corrected now.
Opps, just realised I left debugging on - re-uploading.
Just FYI. Ideally there should be no need to extract the archive manually. Just select install from .zip and browse to the previously downloaded file and you're done.
Forgot about that, thanks.
I can't upload the fixed version yet so if you've downloaded you'll need to edit the addon.xml and change debug to false.
I've added your addon, but in the repo I'm only seeing Alaska Revisited not the original. Any ideas?
Try 'Force Refresh' on my repo from the context menu.
Yep, that did the trick, thank you very much
It truly is an amazing skin, thank you for your insane dedication and generosity.
Thanks, it's all worth it when others like your work.
Installed...great skin ..thanks for updating it
Yeah thanks alot Hitcher, really!
Your work is stunning as always.
