2004-12-02, 02:20
hi,
hehe.. more the done
<span style='font-size:12pt;line-height:100%'>detect xbox hardware values: [done!]</span>
xbox version detection: [done!]
- it detect the xbox versions 1.0 - 1.6 and show it on system info
- i need some feedbacks or logs for 1.5, because this is not implemented yet.. i'looking for a person who own a v1.5
xbox video encoder detection: [done!]
- it will detect which video encoder is in the xbox and show it on system info
xbox modchip detection: [done!]
- this will detect the modchip that is installed on your xbox and show it on system info
- the modchip detection is blowed up so every possible modchip will be detectet!
- if there is no modchip or the modchip could not be detected [like smartxx*] it will show you the tsop flash type!
- all possible tsop flash types are in..
xbox cpu speed detection: [done!]
- this will detect the current cpu speed in mhz this will also show it on system info
- i know this is not very usefull.. but i have implent it..
dvd model detection: [done!]
- this will detect the dvd-rom vendor name in your xbox and display it
hdd model detection: [done!]
- this will detect the hdd vendor name in you xbox and display it.
hdd serial: [done!]
- this will detect the serial number of you hdd and display it
hdd locked state:[done!]
- this will detect if the hdd is locked/no locked.. etc.
dvd firmware detection: [done!]
- this will detect the dvd-rom firmware version in your xbox and display it
hdd firmware detection: [done!]
- this will detect the hdd firmware name in you xbox and display it.
xbox serial number: [done!]
- simple as is.. show the serial n# of your xbox
xbox a/v pack:[done!]
- it detect & shows the a/v pack which is plugged to the xbox!
the values arecart, hdtv, vga, rfu, s-video, standard, missing
dvd zone:[done!]
- simple it shows dvd zone! 0 is all zones same like standalone dvd players!
video & xbe region:[still bugy! need eeprom decryption!]
- it shows the region pal/ntsc eu/usa/jap
xbox live online key: [done!]
it shows the xblive online key!
hdd lock key: [done!]
it shows the hdd lock key!
hdd password: [done!]
it shows the hdd password!
<span style='font-size:12pt;line-height:100%'>s.m.a.r.t read hdd values: [done!]</span>
- s.m.a.r.t: read hdd temp:[done!]
- this will detect the hdd temp an show it ..
the same but temps in 'f':
after some code cleaning i'll upload this patch in the next days to the cvs!
regards
geminiserver
hdd serial: [done!]
dvd zone:[done!]
regards
geminiserver
