Full Version: Some TV Show Seasons are not showing up in the Menu
I was looking for some help with some TV Show Seasons that are not showing up in my Menu? I have been using XBMC for a long time so it shows plenty on banners of all my show and I haven’t had any problems in the past. Now when I get to the “TV Shows” menu it shows me all my shows banners even the ones I’m having problems with. Now the problem is when I open a banner it is empty even if I have a show in there and in some cases I may have 3 seasons but it only shows 2? I do all the scanning to try to add the show and nothing. If I go to my “Video” menu it has the “TV Show” option and if I go that route all the shows are there. It just seems to be a problem if I go via the “TV Shows” option from the main screen.
Help Please
Turn on debug logging and refresh a show. Pastebin the log if it doesn't immediately solve your issue.
I turn on debug logging and that did not solve the problem. Where is the log kept so I can paste it?
thanks for the help
See my sig.
OK, I found the log and have pasted it below. I rebooted XBMC turned on Debuging and scanned a problem TV Show file (Mad Men). My system show everything but season 1?
http://pastebin.ca/1912523
Use pastebin.ca and pastebin the entire log.
Ok Here is the entire log...
Not sure what's wrong there - it finds the episodes no problem, and they're there in the episode guide as well.
Have you tried completely refreshing the show (and all episodes) from the tvshow information?
Cheers,
Jonathan
