Hi
I'm trying to setup Alaska so I can 2 different libraries. I have movies and Standup comedy but they both get mixed into the same library because both types come under movies.
I read that I can have separate libraries for each type if I create another profile. The problem is when I go add a new profile it won't let me choose it, it seems like it is disabled or something. Is it the same for everyone else ?.
Thanks,
I use the genre view for just this same problem never tried another profile in alaska sorry.
Ram2000 Wrote:I use the genre view for just this same problem never tried another profile in alaska sorry.
Do you know how to edit the genre for a particular movie and can there be custom genres ?.
mug2k Wrote:Do you know how to edit the genre for a particular movie and can there be custom genres ?.
I use EMM to sort out all my movies and genres and yes you can add custom genres.
mug2k Wrote:Hi
What options do you choose when creating it?
Does it behave the same in Confluence?
You can look here for more info on what you want to do:
http://forum.xbmc.org/showthread.php?tid=61779
sho Wrote:What options do you choose when creating it?
I'm able to add a profile in confluence but...............
I'm trying to follow your tutorial but the directories you specify to put the keymap.xml(s) don't exist.
I have :-
C:\Program Files\XBMC\userdata (no keymap folder exists inside the directory)
I've created a profile but a folder never appeared
So nothing happens when you click on 'Add Profile...'?
Works for me on both Alaska's.
Disregard my last reply, I forgot about the XBMC directory in the Documents&settings
Hitcher Wrote:So nothing happens when you click on 'Add Profile...'?
Yeah the option simply don't work but I got it working via confluence and switched back !!
