Full Version: Transparency! FAQ / HowTo
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
If you have any questions or problems in getting Transparency to work,
please read the FAQ
in case you feel there's anything missing in the faq, let me know and i'll add it.
ronie Wrote:If you have any questions or problems in getting Transparency to work,
please read the FAQ
Hi there Ronie,
I was looking at the (funny) FAQ to see if I could make my own skin or mod yours somehow, and the link http://code.google.com/p/transparency-xbmc/ does not have a link to all those textures.
BTW is it possible to also change the buttons in settings and default "no-fanart" graphics?
Tx
Mark.
texture are compiled from media folder source.
fredphoesh Wrote:Hi there Ronie,
they're all there, you'll just need a svn client to download the images.
fredphoesh Wrote:BTW is it possible to also change the buttons in settings
sure, just modify all the Button_Side_*.png images
fredphoesh Wrote:and default "no-fanart" graphics?
like hide fanart completely?
Here I am again with another (probably) dumb question, LOL.
I've read the FAQ's for this skin and cant seem to find the directory that shows me what the various icons mean. For example, when I pull up a specific movies information, I see a the director, runtime, cast, plot, etc. Theres also a list of icons that stand for various info, like rated: PG. How can I find out what some of these icons stand forHuh
let's see...from left to right:
  1. resolution (480, 720, ..)
  2. aspect ratio (4:3, 16:9, ..)
  3. video codec (divx, h.264, ..)
  4. audio codec (dts, dd5.1, ..)
  5. source (dvd, bluray, ..)
  6. subtitles (cc)
  7. mpaa rating (see http://en.wikipedia.org/wiki/Motion_Pict...ing_system)
  8. studio logo
How do you show the Shutdown menu on the home menu I never see it show when I turn off XBMC
dallasnights Wrote:How do you show the Shutdown menu on the home menu I never see it show when I turn off XBMC
the shutdown menu on the home menu?
afraid i don't get what you mean...
on the home screen you can hit the power icon on the top-right
to show the shutdown menu, if that's what you mean?
ah i c maybe its cause i am on ATV I cant get to that button I think unless you have another suggestion
dallasnights Wrote:ah i c maybe its cause i am on ATV I cant get to that button I think unless you have another suggestion
why not?
press 'left' or 'right' and you should be there.
(or "up' / 'down' if you use the horizontal menu)
Hi Ronie!
Is there any way to add extra images for the movie genres? I already downloaded the VideoGenreFanart.zip but i don't know where to put the files.
(sorry for bad english. i'm not a native speaker)
nexusplanet Wrote:Hi Ronie!
you can basically put them anywhere you want.
in the skin enable:
Skin Settings > General > Videos - Use genre backgrounds
and select the path where you extracted the fanart pack:
Skin Settings > General > - Path:
Can't find Skin Settings > General > - Path:
and Videos - Use genre backgrounds was in Skin Setting > Icons
Transparency! Version 3.11.7
ah, ok, i probably misunderstood.
are you trying to add genre icons or fanart?
in case you want to add icons for missing genres,
create the folder skin.transparency/media/foldericons/genre/videos
and put them in there.
Yeah, now it's almost perfect.
The icons just replaced the missing ones. Is there a way to replace all genre icons because now i got two different icon styles Rolleyes
