Full Version: [RELEASE THREAD] Cirrus - All updates and new releases
Pages: 1 2 3
UPDATE: Cirrus 2.1
Screenshots...
DOWNLOAD LATEST VERSION (Cirrus_2-1.rar):http://www.mediafire.com/?f57qk8z8fc15wpr
Download LAST VERSION (Cirrus_2-0.rar): http://www.mediafire.com/?0hy41glwhgw91pn
Download OLDER VERSION (Cirrus_1-1-2.rar): http://www.mediafire.com/?gvke2cd65ewddc5
GITHUB REPOSITORY NOW AVAILABLE FOR LATEST CHANGES
https://github.com/crookas/skin.cirrus
Once again we have a revamped recently added, plus new media flags
Changelog: 21-01-2011
  • Moved now playing info and time/weather for low horz menu
  • Added new submenu for horz main menu (press down now for vertical submenu)
  • Fixed bug in music now playing
  • Added new includes for HomeMainMenuLow and HomeNowPlayingLowMenu
  • Added new media flags and option in skin settings to turn them on
  • Changed recently added again
  • moved clock around a bit
  • recently added changed "playedonly" option to false (all movies appear in recently added)
  • Complete overhaul of now playing and recently added for both horz and vert menus
  • Added new skin setting menu items for extra addons/mods/scripts etc
Changelog: 07-12-2010
  • Added Coverflow music view
  • Added Coverflow movies view
  • Added new movies view "Bigposter"
  • Added Fanart view to music
  • Added option to turn on cases or clear cases on for bigposter view
  • Changed DVD/Bluray cases on righlist view are now dependent on the video resolution, rather than the filename hack
  • Removed the bluray/dvd logos - decided that the other resolution flags were enough.
  • Changed fanart episodes a bit (when info is off)
  • Changed Wall music view - changed highlight to white (like other views) and respaced the panel a bit.
  • Added (RE-added) normal cases (as opposed to clear cases) option to rightlist movies
  • Changed Darkened the background more on the video info screen
  • Changed Moved album info to the right when cdart is enabled so the labels don't cover the precious cdart
  • Changed Slowed down the cdart spin speed a bit more so you can see the precious cdart better
  • Changed the seekbar so it doesn't appear when video info is up
  • Changed the video info bar so it shows "paused" when a video is paused
  • Added option to use logos for list on TV Shows level fanart view (tried banners but too wide so can only fit 2 or 3 on screen at once)
  • Changed the appearance of the views menu (the one that slides out from the right)
  • **Big** code cleanup
  • Fixed up 2 bugs which caused UK MPAA ratings to fail (thanks nordstar)
  • Reduced the corner curve of masks and borders all over the place
  • Changed the context menu - looks a lot beter now, plus resizes dynamically according to number of items in menu
  • Added Horizontal home menu
  • Added Low Horizontal home menu
  • Changed recently added again (one day I'll be happy with that)
  • Changed video info flags (480, 720, 1080, etc) to make the more readable
  • Added option to turn off clock and weather info on home window
  • Separated home.xml into multiple include files: mainmenu, submenu, horzmenu, etc.
  • Added option to remove posters from rightlist (movies & seasons only)
  • Cast list on videoinfo page is now selectable, and when selected displays actor thumbs
  • Common ListView ID changed from 50 to 55 (so above mentioned cast list works)
  • Changed - videoinfo gradient added behind buttons
  • Changed some default backgrounds
  • Changed - Videoinfo tv shows shows fanart and logo on tvshow and season level
  • Added - videoinfo cast list on episode level (castlist selectable)
  • Added - videoinfo has trailer button if video has trailer
  • Added - music recently added
  • Skin settings - changed "show video info" and "show music info" to single option "show now playing"
  • Skin settings - removed "show weather" option
  • Added option for home screen to display random fanart (option in skin settings-home)
Changelog: 19-10-2010
  • changed the look of fanart view so it fits in better with the rest of the skin (I must say I quite like it without the info displayed)
  • Changed the look of rightlist view a bit, movies and episodes now display plot (I'm happy with these changes - views are starting to get a similar "feel" while still staying different).
  • Changed rightlist from a fixedlist to a plain list
  • Changed the look of Wall view a bit to fit in better with rest of skin
  • Removed zoom animation from HalfWall and added a simple white border for selected
  • Changed recently added yet again, now looks a lot better I think
  • Changed position and size of now playing on home page so it doesn't overlay the recently added
  • Moved the media scanning dialog yet again,also gave it a bit of a border so it stands out better
  • Removed blank space from around media flag images to allow for better spacing
  • Added much more consistent spacing to media flags
  • Added diffuse to media flags on DialogFullscreenInfo (info that comes up during movie playback when you press i)
  • Made the list for media flags on dialogfullscreeninfo auto size for better spacing
  • Repositioned a couple of labels slightly. You probably won't even notice
  • Localized a bunch more labels that were hardcoded in english (Thankyou .:B:. and GMib)
  • TVLogo had a couple of hardcoded season paths so I localised that too
  • improved the mp3, aac, and h.264 media flags
  • reduced the size of the poster on DialogFullScreenInfo
  • reduced fadetime when moving between pictures in pictures view
  • fixed video info cast only showing first two actors
  • added fanart view to TV Shows, Seasons, and Episodes (whew, that was hard work!)
  • Split ViewsVideoLibrary.xml into separate xmls for eack view
  • Updated studio flags from ccMatrix github
Changelog: 24-09-2010
  • Fixed problem where home menu background for movies and tv shows couldn't be set unless they were set to off in the home menu settings
  • Changed appearance and location of recently added movies and tv shows on home screen
  • TV Shows recently added apepars below movies when 'videos' is selected
  • Changed location of 'media scanning' dialog (covers up top left corner but can't think of anywhere else it could go)
  • Fixed missing background for DialogAddonSettings (eg. screensaver settings)
  • Fixed recently added script error (note - this will now only work for dharma builds)
  • Added <import addon="script.recentlyadded" version="1.0.4"/> to requires section of addon.xml
  • Changed location of DialogSlider to the top (so the subtitles offset doesn't cover the subs, needs testing)
  • Fixed position of window title for music files
  • Changed a bunch of labels so english no longer hardcoded (note: there is still some, all of which are in custom skin settings)
Changelog: 22-09-2010
  • Added dvd/bluray/hddvd cases option for rightlist (turn on in left menu in view)
  • Added option for "clear" cases when case option is turned on (must admit the clear cases look pretty cool...)
  • Fixed tvlogo fallback image appearing over logo when shows are not in a season folder
  • Fanart View - when info is visible the picture now scrolls through extrathumbs folder (and displays normal fanart if there is no extrathumbs)
  • Added lyrics button to Music OSD (enable in skin settings-addons)
  • Added subtitles button to video OSD (enable in skin settings-addons)
  • Changed appearance and location of "loading media" dialog
  • Fixed - Artist/Album label to wide and overlapped with codec info in musicVis
  • Moved now playing info to bottom right so it doesn't overlap with section titles
  • Moved music library sub-headings so they're the same as other sections
  • Changed TV and Movies home menu so that they show UNLESS the "No TVShows/Movies" button is selected in skin settings (ie they are no longer hidden by default)
  • Added ClearArt toggle to skin settings - enables clearart on both video seekbar and videoinfo (TV Shows only)
Changelog: 21-08-2010
  • Added ability to select custom background for custom home menu items
  • Reduced transparency of recently added boxes.
Changelog: 10-08-2010
  • Changed font to an open source free one (still looks pretty similar - probably actually more readable)
  • Added "Clean Home Screen" skin option which removes XBMC logo and bottom buttons (buttons also then become available in the system sub-menu)
  • Added RightList "Slim" option (to left slideout menu) - removes ratings stars to fit more on the screen
  • Added UK mpaa ratings
  • Added conditional "mins" to runtime tags (appears if the video database doesn't have 'mins' in the duration field)
  • Slowed down cdart spin speed
  • Added conditional to tv logo fallback for when a tv show only has one season (ie no season folders)
  • Added clearart to tv shows seekbar (Note: needs newer version of XBMC than 9.11)
  • Added 'get fanart' 'get thumb' etc buttons back onto the videoinfo screen
  • Made the above mentioned buttons look heaps better
  • Wall view now scrolls vertically
  • Made thumbnails a little bit smaller in rightlist episodes view
  • Changed albumInfo screen so it looks like the rest of the skin
  • Lots of little cosmetic changes, new buttons etc.
Fantastic work - looks beautiful. Congrats on the subforum!
Lookin forward to trying this out. Based on your screen shots it looks like it may just be my new default!
First of all well done on the skin it is great as it is.
just a couple of things,
when playing music the cdart overlaps with the music info, can you make that music info is moved a bit to the right so they dont overlap
also can you add an option so that you can make the font a bit bolder like add two gradients of bold in the option screen
then i noticed that the clearart does not show in pause, can that be fixed.
and when you press i for movie info the cast button is not there, if you see big cirrus it is there , and more slick in that department, also if you press left during the movie list you can see the movie info ext, whcih is a nice addition
lastly when you view the music info can you make it with animation that the cdart is shown
thanks
This is a great looking skin, very well done mate!
Have noticed that in Music Viz. the background screen is black, it would be nice to see Random Fanart Backdrops choosen from Music Home Menu. That would be just great.
Anyway grandious skin, compliments.
butchabay Wrote:This is a great looking skin, very well done mate!
Glad you like it! As for music backdrops I'll look at that for the next update - if you point me in the direction of a skin that already does that would be helpful so I can see how its done. Cheers.
Crookas Wrote:Glad you like it! As for music backdrops I'll look at that for the next update - if you point me in the direction of a skin that already does that would be helpful so I can see how its done. Cheers.
Here is what i found in RAM2000's MOD for Aeon Showmix ... MusicVisualisation.xml
!--artist slideshow if fanart exist in define folder -->
    <control type="multiimage">
      <description>artist slideshow</description>
      <posx>0</posx>
      <posy>-</posy>
      <width>1980</width>
      <height>1080</height>
      <imagepath>[b]backdrops/artist_fanart/Random[/b]</imagepath>
      <timeperimage>5000</timeperimage>
      <fadetime>8000</fadetime>
      <pauseatend>4000</pauseatend>
      <randomize>true</randomize>
      <loop>yes</loop>
     <aspectratio>scale</aspectratio>
      <visible>!Visualisation.Enabled + Player.HasAudio</visible>
    </control>
   <!-- end artist slideshow -->
I think the path could be modified, but creating a Random Folder is great, then you could put every picture you want inside ... no special naming rules.
Cheers
I'm wanting to try this out, but how do you get it to work in Dharma? I saw it has addon.xml and figured that I could just put it in the addon folder, but it doesn't show in the skins list.
You can zip the skin folder, throw it in your Home folder, and install it via the Add-Ons menu. "Install from zip" or somesuch.
Francis
DataFran Wrote:You can zip the skin folder, throw it in your Home folder, and install it via the Add-Ons menu. "Install from zip" or somesuch.
Francis
Will this be added to the addons directory?
Best Skin !
It is really a very nice skin.
there is something which no exists in other skins. To change the Genres.So nowon i do not need the Ember to change the movie's genre.
One request. How can i have the Home Menu in Horizontal position and not in Vertical ?
Have a nice day from sunny today Greece......
Wow, this is an astonishing skin!!! Very nice work!
The only thing that keeps me from using it is, that I am using a TV card and tvheadend to stream television. In XBMC i access TV through 'Videos' and the TV stream as a separate share. The channels and the shows' titles are then simply displayed like this 'CHANNELNAME - SHOWTITLE'. This skin however overlaps the two, so they become unreadable. If there is any chance for you to fix this in the near future, I would be most grateful.
Otherwise congratulations to this piece of art and keep up with it!
mikey79 Wrote:Wow, this is an astonishing skin!!! Very nice work!
You mean that you have tvcard in and through XBMC you watching TV channels?
You have Windows?
Pages: 1 2 3
