Full Version: MyMovies Cover art not importing
Have been searching the last two days on this problem and was wondering if anyone else has had it happen or if they could point me to a thread as I am unable to find it. I am using MM 3.18 to store the nfo file in the ts_video folder so I can import the metadata into XBMC. The problem I am having is that when I go into XBMC video->files I can see the cover art for the DVD but it never gets transfered when I add it to my library. All the meta-data from MM gets over but the movie.jpg file doesn't. When I click on movie information in the video->files section to add the dvd to my library, it extracts all the meta-data from the movie.nfo and even shows the thumbnail of the cover art, but then when I go to library view it leaves out the thumbnail. I have this problem on Camelot and Dharma 4
I found this in my log file.
12:32:07 T:5448 M:1010913280 DEBUG: CThumbExtractor:Big GrinoWork - trying to extract thumb from video file K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO
12:32:07 T:5448 M:1010900992 ERROR: InputStream: dvd streams not supported for thumb extraction, file: K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO
then a little farther down this.
12:32:15 T:6604 M:1020014592 DEBUG: CVideoDatabase::GetMovieId (K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO), query = select idMovie from movie where idFile=1
12:32:15 T:6604 M:1019977728 ERROR: XFILE::CFile:Big Grinelete - Error deleting file C:\Users\Aaron\AppData\Roaming\XBMC\userdata\Thumbnails\Video\8\8881e63e.tbn
12:32:15 T:6604 M:1019977728 ERROR: XFILE::CFile:Big Grinelete - Error deleting file special://masterprofile/Thumbnails/Video/8/8881e63e.tbn
12:32:15 T:6604 M:1019977728 ERROR: XFILE::CFile:Big Grinelete - Error deleting file C:\Users\Aaron\AppData\Roaming\XBMC\userdata\Thumbnails\Video\Fanart\8881e63e.tbn
12:32:15 T:6604 M:1019977728 ERROR: XFILE::CFile:Big Grinelete - Error deleting file special://masterprofile/Thumbnails/Video/Fanart/8881e63e.tbn
I believe this is the section where I am initiating the scraper.
12:32:25 T:6604 M:1018871808 DEBUG: CVideoDatabase::GetMovieId (K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO), query = select idMovie from movie where idFile=1
12:32:25 T:6604 M:1018785792 DEBUG: Found matching Full NFO file: K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\movie.nfo
12:32:25 T:6604 M:1018785792 INFO: Loading skin file: DialogProgress.xml
12:32:25 T:6604 M:1018806272 DEBUG: Load DialogProgress.xml: 11.41ms
12:32:25 T:6604 M:1018806272 DEBUG: ------ Window Init (DialogProgress.xml) ------
12:32:25 T:6604 M:1018806272 DEBUG: Alloc resources: 0.04ms (0.00 ms skin load)
12:32:25 T:6604 M:1018773504 DEBUG: CVideoDatabase::GetMovieId (K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO), query = select idMovie from movie where idFile=1
12:32:25 T:6604 M:1019052032 DEBUG: Found matching Full NFO file: K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\movie.nfo
12:32:25 T:6604 M:1019052032 DEBUG: Adding new item to movies:K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO
12:32:25 T:6604 M:1019043840 DEBUG: CVideoDatabase::GetMovieId (K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO), query = select idMovie from movie where idFile=1
12:32:25 T:6604 M:1019035648 DEBUG: CVideoDatabase::GetMovieId (K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO), query = select idMovie from movie where idFile=1
12:32:25 T:6604 M:1019019264 DEBUG: CVideoDatabase::GetMovieId (K:\Movies\30_DAYS_OF_NIGHT_DARK_DAYS\VIDEO_TS\VIDEO_TS.IFO), query = select idMovie from movie where idFile=1
Any help deciphering what all this means would be greatly appreciated. (a way to fix it would be even better)
Aaron
**This is all on a Vista 32 system**
Update:
The issue is with how you set MyMovies up for "online" movies. I (like most who use folders vs iso) have each movie in a seperate folder named for the movie and a ts_video sub-folder to contain the movie. If you choose the default choice of "online (folder)" instead of "online (folder content)" in MM, XBMC will only pull in the meta-data but not the cover art saved by MM.
Aaron
