XBMC Dharma: Grey Theme v3 now available.
Thanx to the hard work of jpf55 there is now an extra colortheme available for Transparency!.
If you're getting bored with the default blue theme, you now have the option to switch to grey instead.
Installation:
the zip file will contain two folders
- copy the file in the 'colors' folder to the 'addons/skin.transparency/colors' folder
- copy the file in the 'media' folder to the 'addons/skin.transparency/media' folder
- restart xbmc
- select the grey colortheme: Settings > Appearance > Skin > Theme
I'm not taking any credits for this as everything was done by jpf55, so a big thumbs up to him!
Download:
http://www.jpf55.com/dl/GreyThemeV3andColors.zip
Very nice... a pleasant change.. I was getting a bit blue. But what happened to my whole whack of shut-down buttons? I spent a whole day making new one's because the old one's didn't fit my fancy.
So how do I integrate them?
Uploaded with
ImageShack.us
Noticed that the home screen title rollover doesn't.
Cheers for the new color theme jpf55, I have been eagerly awaiting your work. Well done, not to sound greedy (ok maybe a little :p ), but any chance of other colours in the future?
treefour Wrote:Cheers for the new color theme jpf55, I have been eagerly awaiting your work. Well done, not to sound greedy (ok maybe a little :p ), but any chance of other colours in the future?
I'm not saying no but with Christmas and family stuff around the corner, it may take a while.
After PatK's buttons, maybe green should be next...
ronie,
A comment you made elsewhere reminded me of my shortsightedness...
Would you have the phoptoshop files for all the media.
I'm thinking layers here...
I made the whole set of grey as png's directly, not smart
jpf55 Wrote:I'm not saying no but with Christmas and family stuff around the corner, it may take a while.
No worries, I completely understand with 2 kids under 2 yrs old, I completely get the concept of " no time". I'm just happy you did it as I like to change things up from time to time.I'll keep an eye out for anything else you may do, thanks again,
treefour
I dig the gray mod. Is this going to be added to the svn or regular release of T!. I'm just curious so I can be prepared when I upgrade T! in the future.
htpc guy Wrote:I dig the gray mod. Is this going to be added to the svn or regular release of T!.
regular: not likely. team-xbmc already thinks i'm pushing the limits as to what's acceptable concerning skin sizes. so adding another 4 or 5 MB is no option.
svn: don't think that would be a good idea either.
i have no idea what will happen if you run TexturePacker on the media folder if there's already a textures file present.
also, i regularly make changes to the code and images in svn, which would make the grey theme outdated before you know it.
Are the links a bit wrong? Can't see where to d/l v3? Thanks for this
ronie Wrote:regular: not likely. team-xbmc already thinks i'm pushing the limits as to what's acceptable concerning skin sizes. so adding another 4 or 5 MB is no option.
Does the add-on system allow skin add-ons? Meaning an add-on for an already installed skin. If it doesn't... it should/could.
ashlar Wrote:Does the add-on system allow skin add-ons?
not yet.
in the future add-ons that can be used by multiple skins (think media flags / weather fanart) may become available as an addon.
colorthemes certainly won't fall into that category.
