Full Version: Alternative to Media Companion ?
Hi guys ,
Is there any alternative to Media Companion out there ?
Ember Media Manager
Thanks buddy...
Ember Media found the fanarts, info and posters of only 4 of my movies .... out of 84 ...
No
***edit***
Ok when re scraping manually it works GREAT !!!
EMM currently has a known bug where it won't scrape IMDB correctly. IMDB changed their structure and the scraper no longer works out-of-the-box.
To fix the issue, force EMM to scrape cast members; I have mine set to scrape the top 15 cast members. This can be done in the settings. Once you do this, EMM will (for some reason) now be able to grab your fanart, posters and synopses.
I also usually use manual scraping with EMM, since automatic scraping has been hit-or-miss.
Could try xmm2 if other don't work for you
http://forum.xbmc.org/showthread.php?tid=85696
