Is there a way to accomplish this? I know pressing down in Home 1 on Settings gets you to Exit, but isn't working for me in Home 2. It also doesn't appear in the 'S' submenu. Am I missing a setting, or is there a config file I can edit to change the shutdown function to exit?
Shutdown in the 's' menu will do whatever you set it to in the System settings ie Exit.
Sorry if I add my question here..
if I want to hide the menu settings from home
how can I turn off xbmc?
I use
this remote with Xbmc Live Dharma rc2 on Acer Revo 3610
Map a button to the Shutdown menu (s key).
Hitcher Wrote:Shutdown in the 's' menu will do whatever you set it to in the System settings ie Exit.
That's what I thought, and I feel crazy because I can't seem to find it! Maybe it's hidden when Home 2 is selected? I remember seeing it once before, but I can't find it now when Home 2 is selected. I'll try going into Home 1 and see what's there. Thanks!
