2011-01-22, 20:41
2011-01-22, 21:33
While watching the movie, simply bring up the menu by holding down your select/center button on the remote.
Then navigate to the audio icon and disable subtitle. You can choose to have that as the default for all future movie as well.
2011-01-23, 20:23
dazex Wrote:While watching the movie, simply bring up the menu by holding down your select/center button on the remote.
cheers!
2011-01-25, 10:37
How?
2011-01-25, 10:40
Play movie - call up OSD, go to Audio section, uncheck 'enable subtitles', then'set as default for all movies' - globally disabled subtitles.
EDIT - Whoops sorry, should have checked which section i was in - those are for a Windows install - don't know anything about iOS.
2011-01-25, 10:44
steelman1991 Wrote:Play movie - call up OSD, go to Audio section, uncheck 'enable subtitles', then'set as default for all movies' - globally disabled subtitles.
I've tried, but cannot get to this on my ATV2. all I can do is FF, REW, Play/Pause. no sub menu... I'm generally very quick with this stuff... what am I missing?
2011-01-25, 10:45
punker101 Wrote:cheers!
That's for Windows, not iOS.
Anyone?
2011-01-25, 10:48
press and hold the SELECT button, this will bring up the OSD, then you can do the above... i've done it, it works...
2011-01-25, 10:49
daerid Wrote:That's for Windows, not iOS.
Anyone?
Works for me on my iPad and ATV2.
2011-01-25, 10:49
sad1f Wrote:press and hold the SELECT button, this will bring up the OSD, then you can do the above... i've done it, it works...
Woot!! Thanks!!
