Full Version: [AppleTV2] Replacing AppleTV Springboard with XBMC at startup possible on ATV2?
Pages: 1 2 3
Anyone know how (if its even possible) to replace the default AppleTV Springboard GUI with XBMC at startup?
This would be fantastic... +1 for the request
+1
Either a dylib (better solution) or rename XBMC.app to AppleTV.app (can't recommend this)
XBMC is not an app as such in the conventional sense, it's a FrontRow appliance which relies on AppleTV.app being loaded.
shuntros Wrote:XBMC is not an app as such in the conventional sense, it's a FrontRow appliance which relies on AppleTV.app being loaded.
you're right, just forgot that
Maybie possible to configure so XBMC.app autom start when ATV start?
Some people will complain about the smallest detail of anything, just in order to have something to complain about. When you put the ATV to sleep, it resumes right where you left off. You only have to start XBMC once and then you never have to see lowtide again unless the power in your house goes out. Is it really that much of a hassle to input the four keypresses needed to start XBMC the 1-2 times a year that would be necessary?
El Nacho Wrote:Some people will complain about the smallest detail of anything, just in order to have something to complain about. When you put the ATV to sleep, it resumes right where you left off. You only have to start XBMC once and then you never have to see lowtide again unless the power in your house goes out. Is it really that much of a hassle to input the four keypresses needed to start XBMC the 1-2 times a year that would be necessary?
I was in no way trying to complain.
Isn't this entire thing about pushing the jailbreking community into figuring out new things?
Now, on the iPhone there are springboard replacements like pogoboard so obviously someone knows something on the subject.
Its not about bitching or complaining, its about figuring this stuff out.
Chill El Nacho. Nobody was complaining, it was a simple question. That's what makes this forum and community so awesome. If you don't like it, don't read.
sandboy Wrote:Maybie possible to configure so XBMC.app autom start when ATV start?
Not at the current time. No one has figured out how to run iOS apps on the AppleTV2.
hi if you have nitotv installed install first xbmc thorugh the installer in the nitotv menu after that go again to the installer and go for the search option type boot - first in the list will be boot xbmc plugin install it.
next restart it boots directly into xmbc
hope that helps
rodrigo
there's already a method for this.
Thank you for bumping this 9 month old thread with information we already had on our FAQ.
Cant beleive the startup script has put my device into a constant crashing loop :-(
Gets to the apple logo then just constantly crashes... tried rebooting, unplugging, reseting etc to no avail
Users beware! Im gonna have to restore and start again :-( and reinstall everything!
Pages: 1 2 3
