Full Version: advise please
I am having some problem with the TV section of XBMC and can't figure it out. The drive format is showname/season (1, 2, 3, etc). One of the problems is with the show "Weeds". I did have all six seasons but XBMC only found 4 of them. Then I deleted the season 1 through 5 to see what happens. What happened is then TV, in library mode, just went away. I have a couple of other too. I have cleaned, and updated, and searched to no avail.
Now, my question is which 3 party program should I use to try and fix this. I have been using XBMC for quite a while and have, over the years used most of them but I suspect they are all different now. I thought, instead of flying at it that I would ask for any advise before I started flying at this thing.
Thank you........
