I continue to get this error on my phone (Samsung Galaxy S, Android 2.1; Windows 7 64bit; XBMC current version)
I/O Exception (java.io.FileNotFoundException)
http://192.168.0.100:8080/xbmcCmds/xbmcH...emInfo(120)
Does anyone have any idea what I might have done wrong?
Hello,
I got exactly the same Exception.
It was running very well, but just the other moment the exception was raising.
I use Version 0.8.5-beta1 Revision 730
Is it a problem of the Server or of Client?
Thank you
olum
I get it as well, it worked before, but then it just started appearing.
freezy? anyone?
i am now using froyo 2.2 and still get the same error..... help!
I still get it all the time, and it's bloody annoying! Please help!
Figured this one out for you guys
I got this same error, and I tried:
-Restarting App, XBMC, PC
-Reinstalled App and XBMC
-Updated/Downgraded App to other versions
Than I started messing around with every combination of setting in the app, and eventually I found out if you change the
port number, it works
I'm using 8081 instead of 8080
So to recap, change port. Let me know if this worked for you guys, it worked for me
NineT9mustang Wrote:Figured this one out for you guys
Than I started messing around with every combination of setting in the app, and eventually I found out if you change the port number, it works I'm using 8081 instead of 8080
I figured it out a while back in my other thread, i should've posted it here as well.
But thanks!
wow thanks for the tip! changing the port number totally worked!
this is a great app thanks to everyone
Tried about 4 different ports, didn't help.
For cases like this, a log would be great. See the FAQ for how to obtain it.
(2012-03-24, 11:48)TSellers Wrote: [ -> ]Tried about 4 different ports, didn't help.
I did this as well, no solution so far. Anyone any help?
