2011-02-12, 03:32
oh how i missed it...my favourite plugin of all time...
and now there FINALLY is a XBMC Dharma compatible addon!!!
so what's this thing got to offer?
weekly forecast on your home screen:
daily forecast with a variety of animated weather maps:
hourly forecast:
10 day forecast:
steps to make it work:
Transparency! skin support:
Tips:
Finally:
weather.com plus thread: http://forum.xbmc.org/showthread.php?tid=95329
hourly forecast:
10 day forecast:
- download and install the addon using the: xbmc-addons repo
- go to Settings > Weather > Weather
and select Weather.com+ for Dharma
- click the settings option below and select a category for the three map lists:
Map #1 List -> Local
Map #2 List -> World Details (Satellite World)
Map #3 List -> (pick one you like)
press 'ok' to save the settings
- T! svn users should update svn now...and you're done :-)
- if you run the stable version of Transparency!
open MyWeather.xml and Home.xml an change all occurrences of:
(Weather.Plugin,weather.com plus)
to:
(Weather.Plugin,weather.weatherplus)
Tips:
- on the weather screen, press up/down to scroll through the available radar maps...press 'ok/enter' to select.
- click the 'zoom' icon to have a closer look at the map
- hourly and 10 day forecast can be selected on the side menu
Finally:
- a big thanx to Nuka1195 for the weather.com plus plugin
- another big thanx to brightsr for turning it into a dharma compatible addon
