Full Version: Howto avoid the LCDd server screen after XBMC exit
Hi!
I have a Antec Fusion with the iMON LCD remote / display.
After futile attempts with Maverick 10.10 I now use it with Lucid 10.04LTS until the imon kernel module problems are solved.
I have been able to set up the LCDd to my humble wishes at startup (welcome, ServerScreen=no,..) and all works fine with XBMC. I have no intervening ServerScreen while XBMC is running. However, when I exit XBMC the annoying "LCDproc Server/Cli: 0 Scr: 0" screen comes back!
How can I control how XBMC is using the LCDd to avoid this?
To get rid of it, I must do /etc/init.d/LCDd restart, and is is a PITA.
BN
Hi
Try
ServerScreen=blank or ServerScreen=off
the old how to's havnt been updated and it appears that the command now only accepts on,off,blank
Wozza
Ok, thanks, it seems to work, at least most of the time.
Thanks,
BN
I've had the same problem, when the PC is started or shutdown it showed the LCDProc Server info.
Changing ServerScreen=blank fixed it for me.
