Hello I'm currently using this skin but it's really annoying that there's no subtitle support in it. is the new beta version coming out anytime soon or is there a mod that supports it ?
Subtiles work fine with "Fusion" if you have the subtitle files allready downloaded.
hit "M" during playback and select audio button all subtile settings are there. for now you can download your subtitles using confluence skin. its not ideal but at least it works.
We will just have to be patient and await the next update from arcanthur but it may be a while as he has said he is busy with "real life problems" hope this helps you a lttle
Open VideoOSD.xml, replace line 280 with this.
<onclick>RunScript(special://home/addons/script.xbmc.subtitles/default.py)</onclick>
