2011-03-07, 00:25
When I ask XBMC to scan my movie content it places cover art on each folder but stores them in application data. How do I tell xbmc not to store them in the thumbnailcache but place them in the same folder as the movie?
rosendir Wrote:When I ask XBMC to scan my movie content it places cover art on each folder but stores them in application data. How do I tell xbmc not to store them in the thumbnailcache but place them in the same folder as the movie?
bradvido88 Wrote:You can replace you're appdata Thumbnail folder with a symbolic link that points to a folder somwhere else.
hymnz Wrote:@bradvido88.. Can you guide me through that part?
hymnz Wrote:It worked as a charm. Thank you
nogi Wrote:Can you post what you did here please for the benefit of anyone else that finds this thread via search for the same issue.
<videodatabase>
<type>mysql</type>
<host>192.168.1.14</host>
<name>xbmc_video</name>
<user>reneg</user>
<pass>password</pass>
</videodatabase>
<pathsubstitution>
<substitute>
<from>special://masterprofile/Thumbnails</from>
<to>\\192.168.1.14\Data\Database_XBMC\Thumbnails</to>
</substitute>
</pathsubstitution>
</advancedsettings>
20:06:47 T:124 M:2188328960 NOTICE: -----------------------------------------------------------------------
20:06:47 T:124 M:2188300288 NOTICE: Starting XBMC, Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Mar 8 2011 (Git:e9e9099, compiler 1500)
20:06:47 T:124 M:2188300288 NOTICE: Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
20:06:47 T:124 M:2188300288 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
20:06:47 T:124 M:2188300288 NOTICE: Running with administrator rights
20:06:47 T:124 M:2188300288 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
20:06:47 T:124 M:2188300288 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
20:06:47 T:124 M:2188300288 NOTICE: special://masterprofile/ is mapped to: C:\Users\Administrator\AppData\Roaming\XBMC\userdata
20:06:47 T:124 M:2188300288 NOTICE: special://home/ is mapped to: C:\Users\Administrator\AppData\Roaming\XBMC
20:06:47 T:124 M:2188300288 NOTICE: special://temp/ is mapped to: C:\Users\Administrator\AppData\Roaming\XBMC\cache
20:06:47 T:124 M:2188300288 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
20:06:47 T:124 M:2188300288 NOTICE: Log File is located: C:\Users\Administrator\AppData\Roaming\XBMC\xbmc.log
20:06:47 T:124 M:2188300288 NOTICE: -----------------------------------------------------------------------
20:06:47 T:124 M:2188279808 NOTICE: Setup SDL
20:06:47 T:124 M:2187939840 NOTICE: Found screen: Monitor generico Plug and Play on NVIDIA GeForce GTX 590, adapter 0.
20:06:47 T:124 M:2186698752 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
20:06:47 T:124 M:2186698752 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<user>reneg</user>
<pass>stealth</pass>
</videodatabase>
<pathsubstitution>
<substitute>
</substitute>
</pathsubstitution>
</advancedsettings>
20:06:47 T:124 M:2186686464 WARNING: VIDEO database configuration is experimental.
rosendir Wrote:When I ask XBMC to scan my movie content it places cover art on each folder but stores them in application data. How do I tell xbmc not to store them in the thumbnailcache but place them in the same folder as the movie?I don't think your actual question was answered yet. If I remember correctly, if you export your library (individual folders type) xbmc will put the pitures (.jpg & .tbn) in each folder along with .nfo for the file.
Ned Scott Wrote:I don't think the original poster is coming back. He did this one post 6 months ago.
Ned Scott Wrote:Renegita: Do this: http://forum.xbmc.org/showpost.php?p=837103&postcount=2
<advancedsettings>
<pathsubstitution>
<substitute>
<from>special://Thumbnails/</from>
<to>smb://somecomputer/folder/etc/Thumbnails/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
19:50:55 T:6288 M:1776226304 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<loglevel>1</loglevel>
<videodatabase>
<type>mysql</type>
<user>reneg</user>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>reneg</user>
<name>xbmc_music</name>
</musicdatabase>
<pathsubstitution>
<substitute>
<to>smb://192.168.1.14/data/Thumbnails/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
19:50:55 T:6288 M:1776218112 DEBUG: Configuring path substitutions
19:50:55 T:6288 M:1776218112 DEBUG: Registering substition pair:
19:50:55 T:6288 M:1776218112 DEBUG: From: [special://masterprofile/Thumbnails]
19:50:55 T:6288 M:1776218112 DEBUG: To: [smb://192.168.1.14/data/Thumbnails/]
19:50:55 T:6288 M:1776218112 WARNING: VIDEO database configuration is experimental.
19:50:55 T:6288 M:1776218112 NOTICE: Getting hardware information now...
19:50:55 T:6288 M:1776218112 INFO: Using analog output
19:50:55 T:6288 M:1776218112 INFO: AC3 pass through is enabled
19:50:55 T:6288 M:1776218112 INFO: DTS pass through is enabled
19:50:55 T:6288 M:1776218112 INFO: AAC pass through is disabled
19:50:55 T:6288 M:1776218112 INFO: MP1 pass through is disabled
19:50:55 T:6288 M:1776218112 INFO: MP2 pass through is disabled
19:50:55 T:6288 M:1776218112 INFO: MP3 pass through is disabled
19:50:55 T:6288 M:1776218112 NOTICE: Checking resolution 12
19:50:55 T:6288 M:1776218112 NOTICE: Default DVD Player: dvdplayer
19:50:55 T:6288 M:1776218112 NOTICE: Default Video Player: dvdplayer
19:50:55 T:6288 M:1776218112 NOTICE: Default Audio Player: paplayer
19:50:55 T:6288 M:1776386048 NOTICE: Loading media sources from special://masterprofile/sources.xml
19:50:55 T:6288 M:1776357376 INFO: creating subdirectories
19:50:55 T:6288 M:1776357376 INFO: userdata folder: special://masterprofile/
19:50:55 T:6288 M:1776357376 INFO: recording folder:
19:50:55 T:6288 M:1776357376 INFO: screenshots folder:
19:50:55 T:6288 M:1777373184 INFO: thumbnails folder: special://masterprofile/Thumbnails
19:50:55 T:6288 M:1777336320 INFO: load language info file: special://xbmc/language/Italian/langinfo.xml
19:50:55 T:6288 M:1777328128 INFO: load language file:special://xbmc/language/Italian/strings.xml
