2011-03-29, 22:38
2011-03-29, 23:32
fair play, testing now
Error when opening:
Full log here:
http://pastebin.com/EvKD0SHz
Error when opening:
T:2746215280 M:1540218880 NOTICE: -->Python Interpreter Initialized<--
22:43:33 T:2746215280 M:1540218880 NOTICE: [PLUGIN] 'VODie: version 1.0.0' initialized!
22:43:34 T:2746215280 M:1540255744 NOTICE: AAADDDDDSSSSS +++++++++++++++true
22:43:34 T:2746215280 M:1540255744 ERROR: Error Type: exceptions.Exception
22:43:34 T:2746215280 M:1540255744 ERROR: Error Contents: Could not get AddonPtr!
22:43:35 T:2746215280 M:1540255744 ERROR: Traceback (most recent call last):
File "/home/xbmc/.xbmc/addons/plugin.video.vodie_1.0.0/default.py", line 20, in ?
VODie.Main()
File "/home/xbmc/.xbmc/addons/plugin.video.vodie_1.0.0/resources/lib/VODie.py", line 127, in __init__
self.ADDON = xbmcaddon.Addon(id = self.ADDON_ID)
Exception: Could not get AddonPtr!
22:43:35 T:3077760896 M:1540255744 ERROR: GetDirectory - Error getting plugin://plugin.video.vodie/
22:43:35 T:3077760896 M:1540255744 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.vodie/) failed
Full log here:
2011-03-29, 23:57
says addon does not have correct structure when installing it with the refocus skin
2011-03-30, 10:54
Ok Thanks for letting me know about the installation issue. I have it resolved and documented.
A new zip (plugin.video.vodie_1.0.1.zip) is available for download.
Follow the steps to uninstall VODie and then install VODie 1.0.1.zip
2011-03-30, 18:13
A new release of VODie (1.1.0) is now available allowing viewing Live TV from Magnet.
http://code.google.com/p/xbmc-vodie/
2011-03-30, 19:42
Excellent Addon Thanks.
It fails when I try to go into TG4
Log file: http://pastebin.com/mizzSfD5
Edit: I think this is a problem with tg4 as I cant seem to access their catch up service through website either.
2011-03-30, 19:54
Hi marathont,
You are right TG4 doesn't work anymore. It looks like TG4 released a new website today !
Will work on that and fix it.
2011-03-30, 20:28
Works great here in Edinburgh. Thank You.
2011-04-02, 11:15
hi,
loving your work.
i'm having trouble with the magnet webtv part of your plugin.
It seems to take an exceptionally long time (3-5 minutes) to load up my channel list, then it gives me a few choices of the current programme playing as well as the next 2, when I click on any of them, nothing happens.
Also, when I try to exit the webtv menu, XBMC stopped responding so I had to kill it.
The RTE part is fine, TV3 shows me list of shows, though some are empty, and others that are not empty give me a script error.
Would really appreciate your help on this one.
thanks!
PS: I'm on XBMC 10.1 on Windows 7 32-bit
loving your work.
thanks!
2011-04-02, 13:55
Great plugin
works in chester
works in chester
2011-04-02, 23:37
Lanre: are you trying to access Magnet Web TV from outside Ireland ? If so that is a problem and a bug was fixed for it (new release on the way). Unfortunately Magnet WebTV is not available outside of Ireland. As for RTE, great news it works for you on windows 7 as I only use Mac and Apple TV. For TV3, yeah loads of shows are empty they dont seem to do clean up but for the script errors, would you mind telling me which shows you are trying to access and maybe the logs if possible. Thanks
2011-04-04, 19:42
kitesurfingie Wrote:Lanre: are you trying to access Magnet Web TV from outside Ireland ? If so that is a problem and a bug was fixed for it (new release on the way). Unfortunately Magnet WebTV is not available outside of Ireland. As for RTE, great news it works for you on windows 7 as I only use Mac and Apple TV. For TV3, yeah loads of shows are empty they dont seem to do clean up but for the script errors, would you mind telling me which shows you are trying to access and maybe the logs if possible. Thanks
hi,
actually i'm in dublin, so it should work ok, right? When I try it on my mac, ipad etc via the browser, magnet webtv works fine.
to be honest, i am less concerned about tv3 and more about magnet - how can i get you the logs? (sorry - bit of a n00b)
2011-04-04, 20:48
well done, this is a great little plugin and works great.
2011-04-26, 21:58
This might be stupid question , how do I install on IPhone , just managed to download xbmc to phone ,
2011-04-26, 22:04
Do I need to ssh into my phone to install ?
