I need to start XBMC windowed.
I'm currently remoting to my PC at home, and it's failing (CApplication::Create()failed) when coming up so I can't make the change in the setting of the GUI.
Is there any way via command line, or config file setting to force it to launch windowed?
I can easily fix this tonight from home, but there is something I'd like to work on now.
There is a setting in the "Settings" to select windowed mode.
Mark
mwkurt Wrote:There is a setting in the "Settings" to select windowed mode.
Mark
Thanks, but read my post again... slower this time :-)
I have issues remoting in as well same error.
I have had to open it local then change the settings to windowed. Then remoting in again starts in windows mode. Other than that I don't think you can fix it remotely.
Edit guisettings.xml. Find:
<videoscreen>
<blankdisplays>false</blankdisplays>
<fakefullscreen>false</fakefullscreen>
<guicalibration></guicalibration>
<resolution>0</resolution>
<screen>0</screen>
<screenmode>DESKTOP</screenmode>
<vsync>2</vsync>
</videoscreen>
and change:
to:
<screenmode>WINDOW</screenmode>
JR
jhsrennie Wrote:Edit guisettings.xml. Find:
<videoscreen>
<screen>0</screen>
<vsync>2</vsync>
</videoscreen>
and change:
to:
JR
That's what I was looking for. Worked perfectly. Thank you!
Learn something new everyday.
