JSON-RPC
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
Threads
- Sending data to a running add-on via JSON-RPC (1 Reply)
- Set and Get Sources For Audio/Video (2 Replies)
- Export video library to separate files. How to request it in JSON? (2 Replies)
- JSON-RPC: Player.Open an HTTP URL (6 Replies)
- JSON and JazzRadio.com (2 Replies)
- API update episode command to actually update instead of add/remove (0 Replies)
- Get PlayCount for plugin:// URLs (3 Replies)
- Pb with 2 links in Important change thread (0 Replies)
- ID question (2 Replies)
- Runscript equivalent for JSON-RPC? (6 Replies)
- Need Help... On.Quit using URL (3 Replies)
- Play video with subtitles via JSON (10 Replies)
- Season handling in Playlist (6 Replies)
- Video Files with a White Space in filename causing parameter error (8 Replies)
- Go to next (Play Music) (1 Reply)
- Stop play music (4 Replies)
- JSON-Schema Service Descriptor spec? (2 Replies)
- Next chapter (0 Replies)
- EPG (4 Replies)
- How to Check OSD Screen Show is actived (0 Replies)
