Feature Discussion (read-only)
Threads
- Addons that are installed as part of a dependency won't be uninstalled with (14 Replies)
- Enter a source which is unconnectable will freeze the GUI (6 Replies)
- Add a remote source (smb) the GUI may freeze for a considerable time (5 Replies)
- Choose a new fanart, poster and if the server doesn't respond the GUI will freeze... (3 Replies)
- Returning from suspend will take you to where you where prior to suspend (9 Replies)
- In the music library there is no automatic scanning of newly added sources at all. (3 Replies)
- Info windows for albums/artists don't make sense in default installs (3 Replies)
- atm there is no way to know if a music share already was imported to the DB. (1 Reply)
- Info/OSD dialog uses an 'X' to close fullscreen, thought that closed the dialog (0 Replies)
- Go through videos on home -> tv shows -> e.g. Big bang theory -> Season 1. T (1 Reply)
- Switch skin, depending on how large the new skin is can take a considerable (1 Reply)
- Entering music after having added some sources still brings you into files view (1 Reply)
- In Music files view there is no access to the scraper settings as in Videos (1 Reply)
- Press play from recently added. If the device where the content resides is... (1 Reply)
- Press play on a movie, from file or library view, while the movie loads.... (1 Reply)
- Try to install an addon where it fails to download. The progress will go... (1 Reply)
- User get's confronted with "addon XY updated" notifications for addons that (1 Reply)
- UI not responding when addons get installed/updated/extracted (2 Replies)
- Issues from Martijn (4 Replies)
- Issues from Montellese (1 Reply)
