TinyMediaManager
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
Threads
- Remove Subtitle Language Postfix and Delete zip file (2 Replies)
- new user - first remark following the use of the software (14 Replies)
- Why does tinymm remove trailers when renaming the movie folder? (7 Replies)
- Release 3.0.4 (0 Replies)
- Export from movies.db (2 Replies)
- Auto assign EP number and season based on title? (2 Replies)
- Season Poster artwork (TV shows) keeps dissparearing (1 Reply)
- Pre-Release 3.0.4 (0 Replies)
- How can tMM rename my files to this format? (1 Reply)
- Can't select episode thumbnail - user error or bug? (4 Replies)
- update selected movie(s) issue (3 Replies)
- Is it possible to automatically update trailers? (2 Replies)
- Add more id links to external webs (1 Reply)
- removing all pictures (2 Replies)
- Tinymediamanager 3+ resets to default after update (4 Replies)
- Add series to TMM with IMDB and and then be able to filter them (3 Replies)
- higher quality backups not showing as new in database (3 Replies)
- Cannot find overall episode number (1 Reply)
- Exporting Poster URL for Movies and TV Shows (1 Reply)
- Should one back up \Tiny MediaManager\cache\image? (3 Replies)
