IPTV Simple Client
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78
Threads
- Trouble with EPG and Icons (1 Reply)
- Amazon Fire TV, IPTV Simple Client, and EPG issues (2 Replies)
- PVR Simple IP Client bug (0 Replies)
- USTVnow integrated with IPTV Simple client? (17 Replies)
- Channel List for TV from M3U which uses [B] [I] etc does not filter markup (1 Reply)
- RTP stream stops after approximately 2 min (0 Replies)
- Live TV lag\buffering\forcing Kodi to exit (0 Replies)
- No PVR Lists in the kodi add-on repository (1 Reply)
- Question: IPTV M3U Files.. (2 Replies)
- epg db not filled correctly-solved (2 Replies)
- Aiuto installazione (6 Replies)
- IPTV Simplae Client Built in Guide (2 Replies)
- WHY IS ABILITY TO TYPE BLACKED OUT (6 Replies)
- IPTV times out on first start up (1 Reply)
- the "get" method to EPG obtaining and URLs inside XML document - are not supported ? (0 Replies)
- Deleted IPTV Simple Client and Can't Get it to Work (3 Replies)
- input channel number (13 Replies)
- Audio skip (2 Replies)
- Increase stream buffer? (0 Replies)
- simple pvr client is gone and cant find it (3 Replies)
