Kodi Application
Sub Forums:
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168
Threads
- Compile issue, fFFMpeg (4 Replies)
- Video Settings - Deinterlace Defaulting to Auto (5 Replies)
- AIRPLAY FUNCTION (7 Replies)
- [Music bug] How to define, which image is used as cover art for an album? (36 Replies)
- Handling of loading tags (0 Replies)
- I'm unable to find the XBMC for Windows.sln file (2 Replies)
- PVR not starting with multiple profiles (34 Replies)
- Karaoke integration redesign (39 Replies)
- How does a 'Play on Kodi' work? (6 Replies)
- No DPI Unaware. (15 Replies)
- CRC / Thumbnail cache naming method? (3 Replies)
- Xcode problem during running Kodi in CSpecialProtocol::GetPath Mehtod (5 Replies)
- XBMC/KODI is skipping the first item of the current playlist (1 Reply)
- Running BuildSetup.bat keeps failing (0 Replies)
- [split] CMake based build system (2 Replies)
- Need help with a system setting change (0 Replies)
- xbmc minified as a server? (856 Replies)
- Nightlie compile error using buildsetup (0 Replies)
- Audio OSD screen pass-through option (0 Replies)
- [Kodi 17 Krypton] configure error libdrm (2 Replies)
