2011-04-25, 20:10
Hi
I have a Sapphire Edge HD Nettop with ION 2 Graphics.
http://www.sapphiretech.com/presentation...1088&lid=2
I installed the latest XBMC Freak Live CD on the integrated Harddrive.
http://www.xbmcfreak.nl/en/xbmcfreak-10-...livecd-v2/
If i plaback .mkv Files with .h264 codec inside i get framedrops where the video stops playing. Audio continues to play normal. After a few frames the video starts again and the whole playback continues normal. Another problem is that i get Video Artifacts like the user in this Forum
http://forums.nvidia.com/index.php?showtopic=181336
My settings are 1080p with 50Hz Refresh Rate. Only VDPAU is enabled, no Sync playback to display or change refresh rate to match video. If i enable the Settings like in this HowTo
http://forum.xbmc.org/showthread.php?tid=70068
the Framedrops and Artifacts are still present. If i skip back and watch the scene again the artifacts are sometimes gone...
I googled a lot about problems like mine, in some threads of the mythbuntu forum i read that users of mythbuntu should set a setting called "vdpaubuffersize" to a special size. How can i adjust this setting in xbmc?
Another posibility for my problems are the Powermizer Settings of the Nvidia GPU. How can i set this settings in XBMC Live?
I cant imagine that it is not possible to get perfect playback with vdpau on my Nettop.
Another problem i encountered: If i try to run nvidia-settings from the command line i get an error that the control display is not set. What settings have i to set that i can run the nvidia-settings tool?
