I have installed an add on from NitoTv that launch XBMC when I boot my ATV.
The problem is I cant get out of XBMC and go to my Apple menu because when I shut it down (the xbmc I mean) it reboots, so I cant even uninstall the addon (I dont know how to use ssh)
Be grateful for any idea
You'll have to learn how to use ssh so you can uninstall the addon...
This is a known issue with the addon, by default it launches XBMC instead of Frontrow, so when you try to exit XBMC instead of launching Frontrow it launches XBMC again... the addon is just doing what it was designed to do.
Do a search on these forums and google and learn how to uninstall packages via ssh.
Once your ssh'd in it will be as simple as typing:
apt-get remove org.tomcool.xbmc-booter
http://forum.xbmc.org/showpost.php?p=738...stcount=11
Thanks, problem solved and learned some new stuff
Thanks a lot bircore! Thought I was going to have to restore and start from scratch!
Jim
I have this same problem i have shh that remove comand but its still booting directly into xbmc does this mean i am going to have to re install everything because that is something that will take ages.
heres my syslog
http://www.mediafire.com/file/gzgt8vg6i0yvybu/syslog
