2011-04-28, 22:29
Hi all,
I'm was running XBMC ver 10 on Windows XP, when after awhile I noticed that I don't have any more free space on drive C.
I went to XBMC user folder [under documents and settings] and I found the log file xbmc.log to be 25GB!
I deleted the file, upgraded to the latest version [10.1 "Dharma"], and after 2-3 hours, the log file is at 500MB and counting, which is obviously not a normal behavior and will probably consume all the space on the drive quite soon.
Using the main menu, under System, the only settings I could find was the debug logging which was disabled.
So, how can I limit the log file size or disable it all together? Thanks.
