Full Version: Fadelabel control in list
Putting a fadelabel control in a list will result in errors in the log file:
"Trying to add unsupported control type 3"
Everything works normal but something is definitely not right if it shows all these errors.
Is there an alternative for the fadelabel in a list, or should these errors be fixed and should I make a trac ticket of this?
Fadelabel is not supported in lists. Usually there is no need for it.
jmarshall Wrote:Fadelabel is not supported in lists. Usually there is no need for it.
I only want to use it on the focused item anyway, so I can just put that outside the list. Took me a while to figure out where that message in the log was coming from though.
