ERrz Wrote:I follow this guide http://wiki.xbmc.org/index.php?title=Ins...MC_on_ATV2 to install the XBMC but am always getting the below error
Err http://mirrors.xbmc.org ./ Release.gpg
Host Unreachable
Ign http://mirrors.xbmc.org ./ Release
Ign http://mirrors.xbmc.org ./ Packages
Err http://mirrors.xbmc.org ./ Packages
Cached Failure
W: Failed to fetch http://mirrors.xbmc.org/apt/atv2/./Release.gpg Host Unreachable
W: Failed to fetch http://mirrors.xbmc.org/apt/atv2/./Packages.gz Cached Failure
E: Some index files failed to download, they have been ignored, or old ones used instead.
did try to google for solution but not able to find any help
am on IOS 4.3
Doesn't look like your atv2 is connected to the Internet. Easiest thing to do is plug it directly into your router (this should get it on the Internet and eliminate any potential wireless issues).
I assume you've been able to ssh into your atv2. Are you able to ping any Internet hosts? For example:
Apple-TV:/private/var/mobile/Library/Preferences root# ping mirrors.xbmc.org
PING mirrors.xbmc.org (212.110.166.220): 56 data bytes
64 bytes from 212.110.166.220: icmp_seq=0 ttl=51 time=101.231 ms
64 bytes from 212.110.166.220: icmp_seq=1 ttl=51 time=102.160 ms
64 bytes from 212.110.166.220: icmp_seq=2 ttl=51 time=147.304 ms
64 bytes from 212.110.166.220: icmp_seq=3 ttl=51 time=104.748 ms
jd2157 Wrote:Doesn't look like your atv2 is connected to the Internet. Easiest thing to do is plug it directly into your router (this should get it on the Internet and eliminate any potential wireless issues).
yes i can ping
Apple-TV:~ root# ping mirrors.xbmc.org
64 bytes from 212.110.166.220: icmp_seq=0 ttl=37 time=290.281 ms
64 bytes from 212.110.166.220: icmp_seq=1 ttl=40 time=274.892 ms
64 bytes from 212.110.166.220: icmp_seq=2 ttl=37 time=287.372 ms
64 bytes from 212.110.166.220: icmp_seq=3 ttl=38 time=294.236 ms
--- mirrors.xbmc.org ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max/stddev = 274.892/286.695/294.236/7.237 ms
Apple-TV:~ root#
When i do a update , it seems to get stuck at mirrors.xbmc.org
86% [Connecting to mirrors.xbmc.org]
follow by the error that i posted earlier.
Grasping at straws but I wonder if there's something wrong with the syntax of your xbmc.list file. Here's mine, notice the blank line (although not sure it matters, try with/without).
Apple-TV:/etc/apt/sources.list.d root# cat xbmc.list
deb http://mirrors.xbmc.org/apt/atv2 ./
If that still doesn't work here's an untested way to clean out your apt-get/dpkg crap that might help. It looks pretty harmless and worst case is you jb again... less time consuming than troubleshooting at times. Btw, any clues in /var/log/syslog? If no one else is having the prob and none of this pans out I'd just restore iOS 4.3 and jb /w Seas0npass and go from there.
http://forum.xbmc.org/showpost.php?p=786095&postcount=5
