If I'm not doing something wrong, this dialog can't be closed with DialogClose and PreviousMenu has to be used instead.
Bug or feature?
Just "Close"? I was trying with "DialogClose()" .
it's Dialog.Close()
note the .
Added dot, but still doesn't work here. Using just "Close" does work.
Dialog.Close(textviewer)
works for sure ;-)
ronie Wrote:Dialog.Close(textviewer)
works for sure ;-)
Yeah, that one works too, but it doesn't look too nice in <includes>
(when making a mouse close button)
Hitcher Wrote:It's a window?
No, it's a dialog on-top of DialogAddonInfo.
Close should work I should think? What is confluence using, or does that not have a button there?
Close definitely works as that's what I use.
jmarshall Wrote:Close should work I should think? What is confluence using, or does that not have a button there?
Yes, using "Close" or "Dialog.Close(textviewer)" does work, so I will use "Close" as more universal one.
Problem is only with "Dialog.Close()" for some reason, and I was using that on "ContextMenu" and "DialogButtonMenu" without a problem.
pecinko Wrote:Problem is only with "Dialog.Close()" for some reason
maybe because that's not valid code?
according to the wiki:
[b]Dialog.Close(dialog[,force])[/b]
Close a dialog. Set force to true to bypass animations.
