Full Version: Dual tuner DVB-S card with tvheadend
Hello,
I know it does not 100% belongs to tvheadend, but I belive You can help me.
My problem is, that sometimes the tuners are loaded in different order. It means, /dev/dvb/adapter0 is sometimes the first tuner, sometimes the second.
To be concrete, it is TeVii s480 card.
Do You have some good trick to avoid such udev mistake please?
Thank You very much,
MaraC
If i remember the latest kernel changes correct, you only have to wait a few months till the latest stable kernel becomes standard in linux distributions.
In these versions the kernel uses unique hardware ids to mark devices...
http://www.h-online.com/open/features/Ke...80510.html
Sorry I don't have an answer for you, but I am writing because I am thinking of buying this card as well.
How is your experience? Any trouble except the persistent naming problem?
Does tvheadend handle both tuners well?
Markus
