Does anyone know if there is any kind of (windows)software out there to easily add nfo files for musicvideos?
I have about 150 musicvideos, but the MTV and the Yahoo Music Videos scrapers only scrapes about 50 of the videos. The only thing I want is to easily add them in my library under Music Videos.
castortray Wrote:Hi,
Try script from this thread:
http://forum.xbmc.org/showthread.php?tid=93241
I use it myself
Hi
Ive seen this thread, but I have no clue how to use this script (or any scripts at all
). Do you mind explain me step by sep? Ive downloaded primalscript2011, and tried to understand what to do, but without success.
Appreciate any help
You copy the script (i.e. the stuff in the grey box) from
http://forum.xbmc.org/showpost.php?p=719353&postcount=3 and paste it into Notepad save it as MakeNFO.vbs (the name MUST end in ".vbs"). You can save it onto the desktop or any folder you want. Now open My Computer and browse to wherever you saved the file and double click it. You'll be prompted to select a directory. When you do this the script will attempt to find music videos in the folder and it will create .nfo files for them.
I had a quick play with the script, and it appears only to work for music videos named "artist - song title.xxx". It will need some tweaking to work for general videos.
JR
Thanks alot guys! Learning new things every day
