Full Version: Latest nighties unable to reload skin using keymap?
Starting from 28.4. I'm unable to use keymap
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<keymap>
    <global>
        <keyboard>
            <F4>XBMC.ReloadSkin()</F4>
            <F5>Skin.ToggleSetting(DebugGrid)</F5>
            <F6>Notification(Testing 123,Hello world)</F6>
        </keyboard>
    </global>
</keymap>
I'm on MAC. Everything works when I revert to a nighty from 27.4.
Did something change? Any of you having problems?
EditConfusedcratch that just installed the latest nightly now and keymap not working on windows 7 either
I encountered this too - got me scratching my head for a while...
The solution is, of course, arse-scratchingly simple:
use a lower case 'f' in your tags:
<f4>XBMC.ReloadSkin()</f4>
thedeadman Wrote:I encountered this too - got me scratching my head for a while...
Ha gotcha that sorted it cheers
Yeah it's case sensitive atm, will probably be fixed soon.
thedeadman Wrote:<f4>XBMC.ReloadSkin()</f4>
This unfortunately does not help on MAC :-(
Funny, worked for me (I'm a Mac user)
This is probably what you should be watching. 126 (PR)
thedeadman Wrote:Funny, worked for me (I'm a Mac user)
This made me recheck it and I found out I edited wrong keymap. You're right lowercase solves the problem.
Thanks a bunch!
No worries :-)
